I am looking for some small wheels (diameter of about 25mm) which have a lot of grip.
Does anyone know where i could get something like this?
Try the RC Wars guys they do some very good wheels ive got some 100mm diameter ones but they have got smaller. You will have to ask? Im sure James or Grant will be on here at some point.
hi gary,
send me an email and im sure we can sort something out for you. Thanks Ed.
regards
James Cooper
Robo-Challenge
We use radiator hose, but dont know if ones that small would be any good as the rubber does wear quickly.
Not quite small wheels but didnt see the point in starting a new thread.
I have got 2 x 150mm wheels with solid rubber tyre of about 1 to 1 1/2 inch thick.
I weighed the bot yesterday and am between 1/2 to 3/4 of kg over weight. I see the wheels as the easiest place to loose weight. The wheels weigh about 1/2 kg each.
Does anyone know of or where i can get some 150mm grippy lightweight wheels?
Thanks Glen
http://www.plasticwheels.com/catalogue.htmhttp://www.plasticwheels.com/catalogue.htm
email James Cooper at rcwars@hotmail.com (im not too sure of his comapny email address!) but he sells a large range of lightweight wheels. have you tried turning your wheel hubs down? you can remove almost half the weight of the wheel on mony!
Cheers Grant
Think i might try that.
What about making wheel from ply wood and fixing a rubber tread on the outside? How durable do you think this would be?
Quite durable so long as your wheels are protected.
Another option that hasent come up here is to mill/lathe your own wheels and have them Vulkalon coated.
Chris - http://www.featherweights.org/forumStimulated
