The Annihilators
Yep its time for a mini tourney, its pretty basic I need 3 robots from 6 people that will go into mayhems to qualify for a place in one of the annihilators if you go out of the mayhem first then you will go into the 18th-13th place annihilator if you go out second then its 12th-7th and if you win the mayhem 6th-1st.
Rules are
Each person enters 3 robots, one of which must be a real robot, one of which must be a vapour the other one is up to you it can be real or vapour.
The weight limits are as follows
100kg for a roller (tracked or wheeled)
125kg for robots that use screws
150kg for shuffle bots
200kg for €˜true€™ walkers (eg anarchy)
Flying robots are not permitted
Robots are allowed to be purely static
Clusterbots are permitted 100% has to be out for the cluster to go out, there is a maximum of 3 parts allowed
Try and include the basic minimum in the stats
For the rest basic robot wars rules apply
So get entering
