Page 9 of 19 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 189
Thread: The Legends Tournament
  1. #81
  2. #82
    Guest
    My job is just to tell Chris to shut up and get on with it, and to call me when hes gotten a life.
    Just kidding Chris, dont go having a cry at me again. :P
  3. #83
  4. #84
  5. #85
  6. #86
    Weight: 100kg (with weapons)
    Weapons: A 10kg spinning drum, three teeth offset from each other.
    SRIMECH: invertable
    Wheels: 4 wheels
    Motors: Two (LEM130s)
    Shape: baldur shape
    Armour: 6mm carbon fibre/kevlar composite over ahrdox chassis, lightweight but very tough
    ill post the order in the morning
    Summary: baldur with a weapon and slightly less armour
  7. #87
  8. #88
  9. #89
    swiss_tony
    Guest
    Obviously I wont go near flubot, as itll be a VERY bad matchup for me. basically hope powerpoint can handle Flubot. And for SDIV, easy. Just get to the sides, i should be able to get under, and then start letting the blade chew away. If I get a KO, ill help matt with flubot. I should be lower, and im faster, so ill get to his sides and try to pit him.
  10. #90
