Page 10 of 16 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 154
Thread: 1st bot
  1. #91
  2. using normal threaded bar isnt a good idea, the thread is to fine and will lock up easily.
  3. #93
    Thanks for the replies.
    Grant: The size of thread Im using is 8mm. The maximum length of the tube would be around 250mm
    Alan: I wondered if that might be the case, its just the threaded rod is all Ive got as Im still getting round to buying a car jack thread (moneys currently an issue), plus the normal threaded bar fits into my drill motor driveshafts (I had to tap them because I botched the modification process and ended up cutting off the threaded axle that was already on the drill )
    Mario: Thanks for the offer - itll take me a couple of days to get round to doing some plans, Im tied up with some stuff just now. I dont have/cant work CAD but I could draw them as accurately as possible in Appleworks and save them as a JPEG if this would be ok for a set of plans.
    Many thanks,
    Lenny
  4. #94
  5. Guest
    Lenny
    You could go to a scrapyard and get an old car jack, look for a box/square type thread your probably get it for next to nothing or even for nothing especially if you tell them its for building a robot. It will also have the correct size threaded attachment to go up a down the thread. Thats what we ended up using in Rampage.
    Ian
    Team Rampage
  6. #96
    Thanks for that Ian, I might try that now that Im on holiday.
    Mario: I sent you an email regarding the custom parts, hope you got it OK, if not let me know, and Ill send it again.
  7. #97
    also lenny, if you use normal high tensile thread (which will be perfectly fine if well greased) then you will not need a complely threaded tube. just get someone to weld a tube on the end of a nut as that create less friction and easier to make!
  8. #98
    Guest
    Im planning on building a chassis out of some sort of box section metal and i was wondering if i should use steel hollow square or aluminium hollow square? and what kind of sizes?
  9. #99
  10. Guest
    no this is for a feather (i know im really confusing)
