Page 1 of 9 123 ... LastLast
Results 1 to 10 of 86
Thread: Help with disc
    I am looking into building a drill motor powered disc within the build of my next robot. (exactly the same as the last Robot from me at the FWS 2004, only fully CNCd out of 10mm ali... The CNCd chassis will be lighter, and will solve many of the problems involved with the last Steel chassis).
    I would be looking into using a 1:1 off the drill motor using a VERY small (about 6.5cm dia)steel disc that would be mounted on the scoop (middle of scoop at front). Could anyone (e.g Ed, Geoff etc) help me with a way to mount the disc onto such a fine (about 4/5mm steel axled) motor... I now have a CNC sponsor who can supply me with ali & steel stock (of MANY sizes) Its just I really need a way of modding this motor or something...
    Any help gladly recieved,
    Cheers, Ewan
    stu's Avatar
    Member
    Ewan - id personaly advise you to maybe mount the disc onto a weapon axel and use some sort of belt to the disc. The drill gear boxes wont take too much of a pounding like that, you whizzing around at high speed with the disc spinning, then bash.
    Mr Stu
    are u just using the motor or gearbox as well? either way i suggest that you have an axle supported both sides with the disc on, and like stu says, either a belt or chain to the motor.
    (I am planning to run it 1:1 directly off the motor) The problem with chains etc is that A good mount onto the motor with a pulley/sproket would be difficult... Either way, I was planning on suppostion the other end of the axle with 10mm ali anyway, no matter what set-up I conclude on...
    Guest
    It may work, but you wont be able to use that tiny axle thats already on the motor.
    First of all, I would suggest that you took a thicker axle and supported it on both sides with some bearings. Then you can just ask your sponsor to make you some adaptors that will join the two axles together!
    It will still be direct drive, but the motor axle wont take any damaged from the impacts.
    Secondly, I would also suggest that you mount the disc on the back. As it will take some time for the disc to reach full speed, it will be a lot more protected if mounted on the back.
    Youll also be able to use the wedge while your waiting for the the disc to actually reach full speed.
    Thirdly, I would suggest that instead of overvolting a single motor, you use two motors at their rated voltage.
  7. ewan i wouldnt ever dream of mounting a disc directly onto an axle. You should have a seperate axle for the disc and connect the two using belts etc. If you dont have the weight allowance for this then you should ask yourself if u really can afford to put on a disc as it is better to have a really well thought out disc than one that will break as soon as it spins or is hit.
    I may not know about pneumatics, hydrolics etc but if theres one thing i know about, it is discs.
  8. #9
  9. #10
    I am trying to make this one safe Geoff
    I need to look at space within the robot (thus why Im not using a bigger motor) This is why I am using a drill motor. A drill motors high RPM is am advantage when it comes to discs, but Ill have to get the spinning mass perfectly balanced. I have decided on a 14mm steel axle, mounted on 10mm aliminium blocks on both sides. 14mm bearings are to be mounted within each block. The disc is to be an 8mm thick steel disc, about 6.5cm diameter, still allowong the robot to be invertable. Im having the centre of the disc milled out to 4mm, aiding the kinetic energy within the disc. I have decided to mount the drill motor (not overvolted) in the blocks Dominic is using in his UK robotics drill mod kit.
    I am using a small belt to the weapon axle (from the drill motor) that will have a total reduction of 1:1.5
    This setup will all be within the 8cm height of the robot. This is going to be a disc mounted under the wedge (youll know what I mean if your saw my bot at the FWS) designed to nibble at the undersides of an opponent as he goes up the scoop...
    Any more suggestions gladly recieved
