Page 19 of 30 FirstFirst ... 9171819202129 ... LastLast
Results 181 to 190 of 299
Thread: Pneumatic
  1. #181
  2. #183
  3. Wow, looks beefy. Any ideas yet on what youd use on the near vertical front tubes to get under your opponent?
    (It is worth making sure that the weight isnt lifted too far forward - but that gives me an idea that if you have some wheely bars extend from the base plate out the front with rollers that only engage with the floor when the flipper is taking a load that might help spread the load of a somewhat painful theoretical 4000+lbs!)
  4. #186
    Guest
    You pulled High Roller out of Robolympic 2007? :sad:
    We were looking forward to seeing it fight Devastator, which is Marauder with a new name and owner (my brother).
  5. #187
  6. Guest
    Can someone draw me a picture to explain the differance between an open and closed pneumatic system with respect to combat robots? This was someones point in an argument we have been having about rules. I was told Marauder is a closed system pneumatic robot and therefore must follow the rules and the other robot was an open system robot and therefore the rules didnt appy to it.
    I thought the differance was in an open you had 2/2 or 3/2 valves and a closed system used 5/3 valves. Am I wrong? Id prefer to be told Im wrong by people who know what they are talking about, because itll make a change to what I have to put up with the last week.
  7. #190
