Page 17 of 30 FirstFirst ... 7151617181927 ... LastLast
Results 161 to 170 of 299
Thread: Pneumatic
  1. #161
    Guest
    Im looking for a fitting that will screw into my dry powder fire exting, with a tee peice on it, does anyone know where you can get such an item????
    ta
    billy
  2. #162
  3. #163
    Guest
    hey, im looking for the pivot part that you can buy for the bottom of your cylinder, i think its called a clevis, i have the one for the top.
    does anyone know where i can get these, i cant remember the bore size of my cylinder, i bought it from technobots about 1.5 years ago, and they said that it work ok, for a feather weight at 10bar, so im not sure of what size to buy, can any one help.....
  4. #164
  5. It will probably have a code on the side of the cylinder in the form of a part number, quote that to the manufacturer and they will help you.
    Or work it out urself?..I have an SMC branded ram with me at the momment, On the side it sais C92SB32-320 The end of the code tells me that its 32mm bore and 320mm stroke. Once you have the bore of the ram, ordering a clevis should be no problem.
  6. #166
    Guest
    thanks guys great help again!
  7. #167
  8. #168
    I see you put your system all horizontal. How do you stop the setup from sucking in loads of liquid co2? Or are you using compressed air or something like that?
  9. #169
  10. like mine.
