OK here is everything which you need to know about the vessels that you can take, there are five in total, I know you don€™t want this yet but it gives you some time to consider while your shopping:
The Delphinus:
A massive titanium warship equal to an aircraft carrier in size and heavily gunned. Passage is free due to its size. Its run by pikachu-goths who generally keep themselves to themselves and don€™t make much trouble.
Cost: free
Speed: 3-4 days
Attack Power: very High
Probability of being attacked: astronomical
The Indigo Dragon
The galleon you saw when you first arrived here, is armed with powerful cannons, is only made of wood and is a bit faster than the delphinus and has much higher manoeuvrability. Its run by pansents, which to give you an idea are three inches high and are to pansies what ents are to trees.
Cost; 5 silver per person
Speed; 2 -3 days
Attack power; medium low
Probability of being attacked; average
The Disco Violent
A small boat, its basically half a glitterball hollowed out and moves very fast because its so ugly the water repels it into the air and skims across the surface of the water.
Its crewed by talking toothpaste tubes. It has no weapons except its too ugly to look at.
Cost: 45 gold each
Speed; 1 day
Attack power; none
Probability of being attacked; low
Size 20m
The Albatross
The most technological advanced ship in harbour, the quickest, most powerful in attack but also smaller and relatively weak in armour. It looks like a Greek trireme but powered using very strong submarine screws. The body is finished to look like wood but is in fact thick carbon fibre over a strong hardox chassis. It possesses torpedoes and an electrical discharge ray capable of unloading several thousand volts into the surroundings. Its prow is solid hardox and in combination with the screws could allow it to shatter the hull of an attacking ship with the rams. The disadvantage is that although the ship is amphibious it needs to steer further out to sea to avoid rocks which could fatally damage it.
Cost: 35 gold each
Speed; 1 . 5 days
Attack power; extreme
Probability of being attacked ;medium
Size 40m
Ole Hamish€™s rent-a-plesiosaur
Is exactly what it says it is, each rides a plesiosaur. Is the fastest meothd by far but if you are attacked you are utterly stuffed as the plesiosaurs will try to dive. Additionally each has a weight limit of 40 equiptment weight.
Cost: 25 gold each
Speed; 0.5 days
Attack power; bite
Probability of being attacked; medium low
Size 10m
