Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 94
Thread: IBC help
  1. #61
    +2>HELP HELP HELP HELP
    Weve blown our IBC up and want to try our axe robot this weekend!
    Have traced the fault to the ATMEL micro and can get hold of one before sunday we need the source code and cant find it anywhere.
    Can anyone help.
  2. #62
    stu's Avatar
    Member
    Would lend you mind, but i lent to Ed and he still has it since Kings Lynn.
    Mark id suggest you contact Geoff Smith at teamscorpion@aol.com he will be able to help im sure. Hes going this weekend etc.
    Mr Stu
  3. #63
  4. #64
    stu's Avatar
    Member
    Not what hes after sadly Aj.
    Hes more technical and needs something more technical. LOL.
    Mr Stu
  5. #65
    Thanks Stu for the quick response Email sent.
    AJ, I used this to trace the probelm this is what I cam up with:
    Our IBC for our featherweight has gone wrong tonight while testing. Ive been tracing the fault from the circuit diagram. What Ive found is that the Rx signals on the left and right channels get to the ATMEL IC but the AUX channel does not and none of the outputs are working. The 10k resistor is fine, Ive checked the oscillator and reset circuit and both are fine so the only conclusion I can come up with is that the processor is faulty. I have ordered a replacement which should arrive before Sunday but I cant find the source code that the manual says is available. Could you please tell where I can find it or send me the file. I hope that a Dataman 48 programmer will program it as I have access to one at work.
  6. #66
  7. #68
    Mark, email Brett at: microsoft (AT) technomagic.com.au
    He should be able to send you the code asap.
  8. #69
    Managed to get hold of Brett last night and he was a great help and sent the source code so all I need now is a chip and a programmer.
    Thanks everyone for your help
  9. #70
    Ok, Got the programmer just waiting for the IC
