Very true. Will do Geoff matey.
Mr Stu
Mr Stu
Fortunately event organisers do not have to follow FRA rules which allows for common sense to prevail at tech checks. M2 as will M2XT uses a 2500mcd LED cluster immediately behind 10mm poly, this is far superior to for example, a vulnerable 40mcd LED surface mounted according to the FRA rules. Im with Stu on this one![]()
Even the Zeobots have a light to comply with this questionable rule and they are surface mounted 40mcd.
Note to self, dont get wound up over power lights again.
Paul
Na you wont Paul - coz your with me on this one, im not on the other side to get you wound upHehe.
But this really is a sticky one.
IF the FRA rules state Have power light on robot which is visable then people are going to have flashing leds, neon lights, mutlicolours, ask questions what type, ask question how big etc, so thats why the FRA has been more accurate of a type of LED to use, these LED surface mounted ones, like the yellow one on Technbots. Its just going to be an on going thing to talk aobut this. lol
Anyway - back to IBCs - they have a small Yellow LED fitted to them, will it be ok if we mount it inside our robots and you can cleary see it through the polycarb pannel - will that be ok for a power light?![]()
Mr Stu
Our 4 IBCs have super bright blue LEDsCan use them as torches in the dark.
Brett changed the LED color in the second version of the IBC since he got sick of being blinded when working on IBC with power in them![]()
Seem to remember that surface mounted only ended up being in the wording so people didnt say
Roboteer - Yes Ive got a power light
Tech Checker - Where is it
Roboteer - Inside, under this panel, behind the batteries and just next to the bottle
I dont believe the intention was to suggest that putting a piece of clear polycarbonate over the light was against the rules.
Ed
Yeah very true. So as Geoff said, maybe the wording of the rules or somethnig needs to be looked at then.
Mr Stu
The LED Thread is too big so Ill post here. On Blue we had a blue power light on a blue painted robot and no one complained. Although we did change it to red every now and then due to wiring up the wrong LED.
On the new version it is Surface Mounted in the only bit of Aluminium chassis, there is 4.5mm of white polypro (not transparent) above it. When the light is on you can see it clearly as about 3cm sq of the polypro turns red. Much more visible than just a single 5mm LED would be.
I also dont remember anyone complaining about Mighty Mouse and the other one I cant spellwhere there is a massive white halogen (I think) light inside his robots that light up through all the gaps in the armour, also very visible.
At the end of the day its the tech checker and event organiser who will say if its expectable or not, For minor rule discrepancies Ive seen tech checkers say they will allow it to run this time but they must alter it for next time, so even if you do turn up with a new robot with a power light not surface mounted then the worst that should happen is you are told to change it for next time.
For a picture of the new Blue, now renamed Litter Hitter because its not painted blue, see my profile. It€™s now CO2 instead of a compressor and has a bigger ram with twice the size buffer tanks and an axe head twice the weight of the original. On the picture the LED is located next to the lower left bolt on the top surface but is not visible as it€™s on the kitchen floor and has the link removed.
I love it Mark!!! Nice One!! And you have an IBC in that as well so it fits in the thread![]()
Mr Stu
Wow, neat robot. How far does it jump when you fire the hammer?![]()
Resistance is futule, all threads will be assimilated by the LED conversation
