Ive got some hacked servos and I wanted to ask some advice to see if I can improve their handling.
First of all, when I originally hacked them for 360 degree rotation, I adjusted the pot along with the trims on the transmitter until the trims were centred and the servo wasnt rotating.
Then I glued the pot in position so it wouldnt move any more, and did the other stuff thats necessary.
Now when Im using the servos they creep an awful lot and Im wondering, first of all WHY!
But more importantly, how I can fix this?
So here is my question, is it better to connect two resistors of equal value together and replace the variable resistor with them?
If so, whats the best way of going about this? Should I check the overall track resistance of the pot using a multimeter, then halve this figure to get the value of the resistors I must use?
Also, how acurate must they be? Should I check lots of resistors (of the same marked value) ustil I get two which are the closest to one another?
Sorry for all the questions but things like this will start to keep me up at night when it gets close to competition time!
I hope someone can help
Cheers
Mike
