Coming up next time in NSBFL 7:
Hell Machine (7) vs Star 69 - Classic
NSA vs Son of Ripper 4.0 - The Moat.
Ill just repeat my tactics I posted earlier.
Those sucker things€¦ suck. I did this before with SOR against Supreme Glory Gamma in PTT4. If that thing is sucking it to the ground I just smash it with the blade and NSA will absorb all the energy and shock itself out. If it isn€™t stuck to the floor I can easily push it and flip it about because the stats say €˜it has no torque€™ so it can€™t push back.
I will keep the blade running all match because there isn€™t a likely chance of me being flipped unless the flipper extension is used. Once at full speed I€™ll just keep hitting that bodywork and causing loads of damage. The odd few flips should rack me up some points too.
Hell Machine vs Star 69
Hell Machine will cut through the FBS with the vertical disc and then turn around to cause damage with the horizontal disc. Hell Machine for me.
NSA 2.0 vs Son of Ripper 4.0
Bah, Son of Ripper will kick this sorry sucker out of the competition![]()
Team Gore
You got Hell Machine mixed up with Sheer Hell, who was last seen wrecking my cameras![]()
Razerdave you naughty boy you!![]()
Team Gore
More wootiness, Mr Goacher!![]()
As for Heat D, Ill have to pick the former NSBFL champ to scoop n pit 69 (rude, innit?) and the former VFT champ to eject the sucker from the contest
This might seem odd, but Im going to jump the moat.
Drive to one end, and turn around, then floor it to get a good take-off and turn into flyer. Maybe in my random take-off, I might hit into SoR.
Groovy fights, dude![]()
I think Hell Machine to take out the 69 in a close battle, and SOR to flip NSA out the arena.
Wow everybodys thinking along the same lines as me!I feel special...NOT! :wink:
Im with Steve, Andy, and Scott here
Team Gore
I have a change in plan.
Stick on the rear flipper extension (think Gravedigger in S4), and aim to get underneath Son of Rippers side and flip it over, whats cool will be that I aint going to put the suckers on for the flip, so I will hop as well.
