NAME- The deer (was crusher chaos)
SHAPE- Invertible box
COLOR- the robot and claws are a dark green color
WEIGHT- 100kg
DIMENSIONS- 1m x 80cm x 25cm
SPEED- 15mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- It has 6mm at the front due to the claws and has 0mm at the sides and rear without skirts 6mm. The skirts also work both ways up.
ARMOUR- 3mm hardox
MOVEMENT- 4 inner wheels that make the robot invertible
POWER- 2 x S28 Magmotors on 24v.
WEAPONS- it has a front pair of horizontal hydraulic crushing claws set up like deers antlers like you fine in extreme destruction. The claws have 3.5 tones of crushing force on the front tips of the claws at the middle is 6tones and right at the back it has 8 tones of crush. The claws are powered by hydraulics through a 120mm bore rams at 3000psi
NOTES- invertible, wide base means I wont topple while the deer is crushing
STRENGTHS- Very powerful weapon
WEAKNESSES- it could be turned into venison
Name- Panicking (previously panic 3 GTI 2)
SHAPE- Low invertible box
COLOUR- White
WEIGHT- 98kg
DIMENSIONS- 65cm x 60cm x 18cm (Length x Width x Height)
SPEED- 23mph
TURNING CIRCLE- 0 mm
GROUND CLEARANCE- 0 mm at front due to forks, 0 mm at sides and rear due to skirts 5 mm with out, the skirts are hinged so flop over when the robot is flipped
ARMOUR- the robot is now covered in 5mm hardox
MOVEMENT- panic now uses 6 Vulcalon wheels to give extra pushing power
POWER- 2 x LEM130€™s on 36 volts
WEAPONS- on the front the robot has a pair of invertible lifting forks, the forks are like those on panic attack, the forks are powered by 2 linear actuators
STRENGTHS- Low ground clearance, reliable weapon
WEAKNESSES- previously lost to spinners
NAME- Happy birthday party pooper (previously Birthday party pooper) (ta to frank for the help he gave me with finalising this robot)
SHAPE- invertible disc (like gyrobot)
COLOUR- Blue
WEIGHT- 150kg
DIMENSIONS- 100cm diameter X 20cm height
SPEED- 10mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- its about 10mm but 3mm under the blades
ARMOUR- 6mm titanium body
MOVEMENT- it runs on 8 inner anarchy style legs.
POWER- 2 x S28-400€™s Magmotors on 24v.
WEAPONS- it has a powerful spinning shell spinning at around 1500rpm weighting around 65kg powered by 2 X LEM-130s running at 48v, it has 12 typhoon2 style teeth around the out side 4 around the bottom 4 around the middle and 4 at the top
NOTES- all components have been shock proofed with rubber around them.
STRENGTHS- very destructive weapon
WEAKNESSES- easy to push if weapon not spinning
NAME- Call out hook
SHAPE- low box wedge (like storm 2 but not invertible)
COLOUR- red and black with gold diamonds on it, the hook and axe weapon are silver
WEIGHT- 100kg
SPEED- 23mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm at front wedge, 0mm at sides due to skirts 6mm with out 6mm at rear, varies under weapons
ARMOUR- 4mm hardox
WHEELS- 6 inner Vulcalon wheels
WEAPONS- Weapon- On the top of the machine, there is a 360-degree rotating turret, on which can be mounted 2 weapons. The first one is a large CO2 powered lifting arm, running off a 80mm ram at a pressure of 750psi. It has a hook shaped arm on the end, which is designed to pull up and puncture wheels, whilst lifting at the same time, and also to enable it to penetrate skirts. This ought to lift around 268kg around 40cm into the air at maximum. The other weapon that can be chosen is a double-headed horizontal axe shaped like that of Terrorhurtz, which will spin around on the turret, enabling him to do both damage by spinning and hammering. This should be enough to cut thin titanium, and dent the thicker sheets. The turret is powered by a LEM 130 geared at 4:3 giving good speed it spins at around 2000rpm and reaches it in around 3-4seconds
SRIMECH- the lifting arm which can self right from any position due to the turret
STRENGTHS- good weapons, good pushing power
WEAKNESSES- if the arm is spinning round it may topple
NAME- It may be small but its still bad and pink
SHAPE- invertible box
COLOUR- Pink
WEIGHT- 59kg
SPEED- 20mph
TURNING CIRCLE- 0
GROUND CLEARANCE- 0mm under front scoop, 0mm under sides due to skirts 6mm with out.
ARMOUR- 3mm titanium
WHEELS- 4 inner vulcalon wheels
POWER- 2x LEM130 Lynch Motors on 24v
WEAPONS- it uses a front 3mm hardox scoop which has a chain flail spinning vertically
SRIMECH- invertible
STRENGTHS- good rammer
WEAKNESSES- hard to control
spikey 2 and my feather weight will be up later
