Artros vs El Persistence
T.O.D.D vs Ankle Biter EVO
Kruel Intent vs Pink Panther
Deep Impact 2 vs Agitator
See? All present and correct. Stop trying to make me paranoid![]()
Finished with my woman cause she couldnt help me... Ooops, sorry about that![]()
Overdrive vs Sparkstorm vs Maximum Velocity
Same stuff, drive about ramming and pushing whichever is nearest.
Wheres Crush 2?
I only know where it isnt...
Crush 2 now replaces T.O.D.D in heat F, taking on Ankle Biter EVO.
With part 1 of the Grand Prix final finished here are my:
Tactics
Heat 4 -
NSA vs Son of Ripper 4.0
Run away and try to get some good shots in onto the top of Son of Ripper 4. My hope for NSA is nil.
Heat L -
Push-ish vs Squish
The razer clone with a hydraulic arm which is slower than a snail![]()
Ram at it, get underneath and flip over onto its back, without a weapon that can self-right it within an hour, its pretty well stuck.
Heat N -
Seggy the 3rd (6) vs Flipping Hell
Set-up depends on Arena
Heat O -
Hefty Kick in the Balls vs Black Chalkie Beard
Spilt up, where one part is around the front, the other half will be around the rear flipping it over.
Lightweights -
Hell Hound vs Trisadekaphobia vs RQRCL
Try to flip the robots over.
Middleweight -
Killoteeny vs Scarlek vs Black
Steve, want to gang up on Scarlek?
For this fight, I will be using the second wheel type to hide the wheels from Scarleks 8cm high disc. The main tactic will be to go into Scarleks rear end, getting under the disc and putting one of the swords where the gap is and cause pain for Matts machine.
Sheer Hell (5) vs Stratos-Fear -Oh dear. I€™m gonna have to attack the wheel protection with all I got, and, if I can€™t rip them up, then I€™ll hammer them down, by spinning the vertical disc in the opposite direction in order to bash the metal down into the wheels
Hell Machine (7) vs Star 69 - Stick an axe through its bonce and stick it in the pit. Failing that, I€™ll try and stack it against the wall, but if I get The Moat, I€™ll stop the star spinning once, then shove it out (that is if it doesn€™t knock itself out)
ForcePower Turbo vs Flaming Hell - can I have info for Forcepower Turbo?
Seggy the 3rd (6) vs Flipping Hell -can I have info for Seggy the 3rd?
Pillow Torque vs Hells Angel vs Scorpion Junior - can I have info for both pillow Torque and Scorpion Junior ?
Hell Hound vs Triskaidekaphobia vs RQRCL-I€™m gonna go for Triskaidekaphobia (that€™s its proper spelling BTW), and its 2mm armour won€™t stand a chance, I just have to get stuck in with the jaw before that cage spins up. Besides, what€™s up with the Number 13? That€™s my 2nd favourite number (my first being 666) Oh, I forgot to say in the stats, Hell Hound has a tail shaped cable pulled self righting arm if he is indeed flipped onto his lid
Blazer vs Hell Fire vs Blizzard-I€™m gonna concentrate on Blazer because I know of that one. The saw will make light work of the ali protecting the wheels, and at only 40kg, thowing it out of the ring should be fairly easy. But I must keep wary of that screwy Blizzard, the discs sound dangerous, and its pushing ability might be good, but there is no way he€™s going to catch something as nippy as Hell Fire
F.B.S (Fat Billy Sastards)
Weight- 50kg
Dimensions- H- 40cm L+W- 60cm
Speed- 8mph
Shape- Typhoons shape, but the slope is curved.
Ground Clearance- 5.5mm
Turning Circle- 0
Armour- 8mm Aluminium Boron Carbide
Locomotion- 4 thin plastic wheels with a 20cm diameter and mounted in a Typhoon style setup..
Power- A 24v Ventilator battery powering 2 Bosch 750w motors
Failsafe Position- Under tip of cone, which is hinged
Paint Scheme- Red with Doughnuts painted on
Weapons- True Full Body spinner weighing in total 26kg with 4 steel blades along the edges. This is powered by an APC back up motor, spinning the weapon at 2000rpm and produces 74Kj in the weapon.
Srimech- A small Ziggo style flag on the top, which self rights the robot as well as showing the direction
Strong Against- Most things
Weak Against- Horizontal Pincers, Fast well-armoured flippers
Robot most compared to- Ziggo
House robot most feared- Dead Metal
Strengths- Very powerful weaponry
Weaknesses- Manouvreability
Ooops, forgot we entered 4 heavyweights...
Ram it back through the gates of Hades!
For Dave, here are ForcePower Turbos stats: http://mattyhakaman.proboards15.com/index.cgi?board=AJ&action=display&num=1087079562http://mattyhakaman.proboards15.com/...lay&num=108707 9562
Wedga Revo vs Veg 2
Normal tactics from my bots here, ram and flip.
And... Pillow Torque vs Hells Angel vs Scorpion Junior
Why do I get the feeling this match was set up? :P
I dont know, because it wasnt set up at all.
First two fights will be written shortly.
