It depends on how much power you expect to waste. That depends on how much tension you are putting on the belt or chain. At low tension such a light setup will be better, for relatively heavy tension it might not and a plain nylon roller for a belt need not be heavy. One problem with toothed belts is getting enough width to make the idea viable. I havent really looked into how well it would work out in practice.
