Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 81
Thread: Axe mechanism
  1. #71
    i come up with the same as gordon, about 4.8Nm.
  2. #72
    Ok, cool. Is trying to figure out how fast the axe comes down and with how much force.
    If Energy = (MxP^2xs^2)1/3 and Sweep time = (2xS^2xM/P)^(1/3), I require s (sweep distance) to work it out. This is measured in Radians, right ? My axe has to travel about 200 degrees.
    Say I use this radiator fan motor (No Load RPM is 4800rpm)to power my axe through a 12:1 ratio on 24v (belt or chain, I havent deciced, but I think belts would lose to much energy), the axe arm is 330mm long, and the arm weighs in at 1kg and the head weighs in at 700g.
    Motor Torque: 4.8Nm
    What will I end up with in terms of energy of the blow and speed of the blow ?
  3. #73
    well 200 degrees is 3.49Radians
    Im in college atm so i dont hasve time to wo4k out the whole equation
  4. #74
    Same here funnily enough :P
  5. #75
  6. 73 joules is not a lot :S
  7. #77
    Gord- Are you using the same fan motor in your hammer that you used in Arggh?
    James and Grant...dont know what You mean by cost effective...I bought you one of the fan motors you destroyed so you owe me lol
  8. #78
    At 73 Joules a conventional electric feather will already be beginning to jump. For many opponents it is a damaging level of energy. Feather hammers are handicapped in two ways compared to their heavier counterparts. For a given weight they cannot make as high a energy to weight as a heavy without generating more power to weight, as there will be less time in which to generate it. This *is* somewhat possible for motors and gearboxes which can increase in power performance as they get smaller, but is more of a challenge for available batteries which put more sharp limits on performance.
    With pneumatics so much power can be made available, unless you are stuck with low performance components it is not in my mind even an issue, pneumatics scale down remarkably well. Given the need and motivation it is possible to construct pneumatic parts in a heavy capable of reaching hundreds of kilowatts of power. The second disadvantage is that gravity is a less significant effect the smaller you are, so jumping becomes a problem even with a reduced energy. It is easy for feather to lift other feathers, they dont have to move things as far so the stresses are less.
    There are a couple of ways to generate more energy, the simplest is often to increase stroke or shaft length. Neither are totally problem free. It isnt worth increasing the head mass much so you need to concentrate on power. Secondly more volts, it works best to really punish the motors and the batteries. If you havent thought of overvolting your probably just not trying.
    If you use a toothed belt or chain drive, plausibly you might be able to handle shock energy elastically in the tensioners, and avoid a clutch - if you are careful. The tensioners have to be sprung low friction rollers for a timing belt or sprockets for chain.
    The effect on the overall energy shouldnt be too great. If you can cut your own sprockets it might be possible for you to make a torque shaping linkage. However with only one ratio per position, you cant get much of a retract jolt, the same effect is there for elliptic gears except you wont have the shock absorption either. This kind of torque shaping mechanism can be used to reduce jumping to a degree. Shaping mechanisms work efficiently with sprung energy storage, though too much use of these mechanisms can cause trouble in self-righting (and possibly retract). The former might be less of an issue in a feather.
    Nick.
  9. To tension the drive chain for the axe, cant a use a piece of self lubricatin plastic like George fransis does for Chaos 2s drive chain ? saves the weights on spring loaded ones
