Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 81
Thread: Axe mechanism
  1. #61
  2. I remember quite well the conversations between you and james when decided on what to use. You were saying 6:1 was perfect and james thought around 12-15:1. After long discusions and some talking to john ried, the outcome was 6.6:1 would be the best and most efficient for the job.
    Worked well in the end, just the quality of the motor wasnt much to be desired. Might look at making another along the same line, but with a better quality motor.
  3. #63
  4. we used approx 6.6:1 but this was way to low and was basically a cost driven solution.
    nah well. welding wasnt a good idea
  5. #66
  6. Whats a Fusee drive ?
  7. #68
    Like the arrangement on beta, using snail cams.
    http://www.johnhmreid.dsl.pipex.com/beta/progress/leafchain.jpg
    http://www.johnhmreid.dsl.pipex.com/.../leafchain.jpg
    Its only one option, there are others. In a heavyweight a clutch is practically mandatory especially if you use anything resembling an ETEK to power it. You can probably get away without one in a feather with some motors if the hammer shaft is sufficiently flexible. In that case, drivetrain mass will have to suffer so the gears dont get damaged.
  8. #69
    I didnt realise about clutches for HWs. Ill be sure to note that when I get back to building it.
    I know that the Fan motor produces about 600W and 4800rpm at 24v, but Im trying to find the torque of the motor (I can probably work out the torque from the power and rpm, but I cant remember which way around it goes right now), so that I can work out what speed and with how many Kj my axe will hit with
  9. #70
