one more question about how fast do the whele cair motors go with the gearing what rpm and how many amps do they draw and the same question for the radator fan motor and do either of them need any moding
The fan motors Ive used are from a Peugot 405 (not sure how many of them you will find in the scrappy)
The main reasons I chose these motors are.....
High torque, they are large diameter motors and have some grunt!
relaible, they last forever and so far have not kicked out any EMI of note.
arguements against.....
heavy, 2.2kg each.
back emfs, not too gentle on controllers.
I used mine to spin a 3kg, 18bar up to 6000rpm inside 3 seconds, without gearing. May be a bit underpowered for the current generation of heavyweights, bt using 4 will compensate for that.
I used the very same fan motor for an electric skateboard! Its quite capable of propelling 100kg of me at 12mph (running a 12v motor on 24v, geared 5:1 on 10cm diameter wheels). Motor barely even gets warm.
The Audi 100 type motors produce more torque - but burn out half way to the pub!
Si
