I am going to add this. It does have potential as a weapon. The WHOLE weapon setup will weigh only 2.0kg (using the weight saved from changing the chassis & armour to 10mm aluminium all over). The old steel chassis weighed WAY too much for a featherweight, and was armoured way OTT in areas. I dont think many spinners will stand a chance of going through 10mm aluminium anyway (I am using the same construction idea of tapped holes all over holding the chassis together as http://www.teammadcow.com/alos.htmhttp://www.teammadcow.com/alos.htm this robot looks amazingly well built, and his is only around 6kg).
The whole drive system will be exactly the same, so itll still push/ram as it used to, the only difference being the disc can be used as a weapon while pushing...
