Page 46 of 65 FirstFirst ... 36444546474856 ... LastLast
Results 451 to 460 of 645
Thread: Roaming Robots, Winter Tour
  1. #451
    Guest
    A pink pig rated higher than behemoth,can opener and my robot the wall for that matter,-thats some pig,your having a larf arent ya.
  2. #452
  3. #453
  4. #454
  5. Karoline,
    All I can suggest is that you load Internet explorer (I assume that the one you are using) without being connected to the net and clear out the Temp files and Cookies, then click the Default settings button, set the security & cookie settings to low and test to see if it works. If so then increase the security/cookie settings to midway. The highest settings are a real pain, Have you got SP2?
  6. #456
    For the Doncaster event weve found an Innkeepers Lodge about 1.6 miles away for the venue
    Website is http://www.innkeeperslodge.comwww.innkeeperslodge.com
    Room = £45 per night (double or twin) and includes breakfast
  7. #457
  8. kane's Avatar
    Roboteer
    Run AdAware from lavasoft
    http://www.lavasoftusa.com/support/download/http://www.lavasoftusa.com/support/download/
    Click the Majorgeeks link at the bottom and then click one of the mirrors. With SP2 youll need to click the if your download doesnt start click here link to download the program.
    This will check your system for spyware, which at best slows down you computer and compromises security. At worst, it makes internet explorer completely disfunctional.
    Kane Aston
    http://www.makerobotics.com
  9. #459
  10. same here
    jonno
