Good Point John, We use PCM but have to be very careful upon powering up to make sure the failsafes become active. The default mode for the PCM Rx we have is upon lost of signal to stay in the last good position until the Tx updates it after a few seconds. They are the best type around because theyre in the Rx. We still use other failsafes built into the mixer/interface in case a cable becomes unplugged or the Rx battery becomes flat.
Interesting point though as when we were going into the Arena at Series 7 It failed the quick tech check because the Tx had lost it memory and returned to its default settings. It was quickly fixed and passed the second check. FRA events currently only check this once at each event! If that had not been checked at Series 7 then we would have gone into the arena without working failsafes.
