All,
Ive been designing a simple speed controller (well, kind of) based on logic gates, transistors and relays to allow F, B, FL, FR, BL, BR and Spin L and R all at full speed only. Im by no means an electronics whizz so Id appreciate some guidance.
Firstly - can I use 74 series CMOS logic gate ICs on 12V? If so, do I need to put resistors in series with them or anything in order to increase/reduce the current? My design is entirely based on this premise and if this is not possible then Im going to need a rethink, or a separate level of relay switching a relay switching a motor.
Second : I bought a couple of MOSFETs and some automotive relays at weekend. When I connected battery to MOSFET (drain I think) to Relay (via Source of MOSFET) to battery, the relay activated whether the gate had a current or not. If I connected the gate the relay stayed on even when the drain was disconnected, but if I just connected gate and source, the relay did not activate. Are my FETs fried, am I using them wrong, or do I need some extra resistance or something to prevent the FETs being triggered?
Thatll do for now. Im sure any responses will throw up further questions.
Cheers
-- Kev
