You could just connect a led & resistor on one of the channels, this will blink (too fast for you to see) if SIGNAL, off otherwise.
But, this is likely not what you want, since it will only show if there is a signal, or not, not if your failsafe has kicked in properly.
EDIT: Because of the previous post, am I to belive you have a PCM system? If so, it will obviosly not work.
