Jim, that would not work for ours with 4QDs as there is a bypass bleed resistor that charges up the capacitors to allow enough power to activate the relays when the ignition switch is on. Its reason for being there is to prevent sparks when connecing the link. Its a bad idea forget it.
Roger, Use some common sense please. The power light is there because experiance have shown that robots in the past have removed thier link and have still been active (ie the link did nothing). IF and only IF the light is fitted correctly will you see that it is still on but it would alert people to the fact that it is still active in the pits. If I see a robot with any lights on it when its in the pits I would certianly treat it with caution would you? If you power up your robot and the light does not come on then whatever the reason (Light / link fault) it should not be allowed to fight. How many people to you expect to be at Yeovil. How many were thier last year . Dont put people off going to your events as Im sure that many wont go if the FRA dont approve your event.
