Page 11 of 18 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 179
Thread: Drills
  1. #101
  2. #102
    Try This http://www.nutool.co.uk/ProductCatalogue.asp?ID=J02&Section=Power%2BTools& Count=1http://www.nutool.co.uk/ProductCatal...+Tools&Count=1
  3. #103
    team_ireland
    Guest
    Mark is it easy to get around the Hammer Action and the 2 stage gearbox?
  4. #104
    i can get hold of some 18v nutool cordless drills for £12 a go although once postage is added i dont know how cheap they would be
  5. #105
    Ian, The Hammer Action itself is not too bad to deal with and the easiest way I can think of is leave the Selector on the gearbox, this allows you to also use the torque setting if you wish. The other problem is most Hammer drills are 2 speed and once youve taken the drills casing apart you need to fix this selector in place. We re-made the gearbox housings taking out all but the ring/planet gears needed and placing them in an aluminum housing. The 30V gearboxes were made completly in the wheels and on the 12V ones we left all three stages in so this featherweight is really slow but it burnt a few motors out on the higher ratio so this was a safer option.
  6. #106
  7. Its the NTCD18K from http://www.nutool.co.uk/ProductCatalogue.asp?ID=J02&Section=Power%2BTools& Count=1http://www.nutool.co.uk/ProductCatal...2BTools&Count= 1
    If anyone is interested I will need to know soon as I do not think the offer will last long
  8. #108
    Found some pictures of those 30V ones.
    ftp://www.bignipper.no-ip.org/Little%20Axe/DSCF0060.JPG>60
    ftp://www.bignipper.no-ip.org/Little%20Axe/DSCF0061.JPG>61
    ftp://www.bignipper.no-ip.org/Little%20Axe/DSCF0063.JPG>63
    There is a rough size comparison of them with the compreesor motor which is the same size as the 18/12V drill motors and on 61 you can just about see the gearbox inside the wheels.
  9. #109
    team_ireland
    Guest
    FYI these pics are very very large so unless your broadband expect very very long download times!
  10. #110
    Not limited to space so didnt see the point in making them smaller, but just limited in the number of connections.
