Thats more like it!!!!!!Ihope the next 4 way melee I am in is 3 flippers , and 1 spinner!!!
eheheheh Der Boyz
eheheheh Der Boyz
Well, I might as well join up too, as I have joined the flipper club!! (And I dont like spinners!!)
TTFN
Jon
count me in too
ahahahahah our gangs bigger than their gang!![]()
Can i join?![]()
Never liked spinners anyway.LOL!
Stu
Stu.. you drive at least 2 spinners you spanner!
I dunno, weve got spinner denial now :sad:
Sam
http://www.shredderteam.comhttp://www.shredderteam.com
http://www.robotcrusade.comhttp://www.robotcrusade.com
Heheheheheehe Flippers for President![]()
Tony, I wish I could make a crusher with 12500lbs force it would be quite effective and fast with CO2.
Now you Know it can be done mark a Impact cylinder
at 1000psi + a decent fulcrum, impact cylinder
produces 7 ton at 100 psi so anything is possible
I have always maintained that roboteers are slightly unhinged now I am sure!!!![]()
Mark, the only thing you need is a ram with a 4 times as big surface than a hydraulic crusher uses.
If Razer has 9 tons on the ram, this would be a 3 ram. To equal that with CO2 the ram would be a 150mm diameter ram.
If you know that Kan Opener uses a 50mm bore(if Im not mistaken)As does TiberiusIII, then a 100mm CO2 ram can deliver about thesame.
Now, Tough As Nails doesnt do as much damage as intended, but acts a way faster, due the fact we downgraded from Hydraulics( expensive/heavy)to a custom FP CO2 System.Also the fact we have a rather small leverage-2 to 1,and a gian surface in stead of points means we are nice to the opponent, a kind of sturdy hugging is all you get.
In other words, It is possible.A pneumatic crusher.
