Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
Thread: First ever real build lews featherweight
  1. #21
    Looking very tasty - what thickness is the Carbon Fibre?
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
  2. #22
    Supermotolew
    Guest
    Thanks Lucy!
    That battery protector plate is 3mm but i think ill do the esc brackets in 1.5mm there purely to support the components. You can see the intended X shaped esc brackets here with blue hdd rubbers onthe corner.
  3. #23
    Supermotolew
    Guest
    Things have been a little tight over xmas so i started working on the box for the battery as i already had the materials.
    The Battery enclosure is looking good just awaiting some foam to cnc a pocket into.
    Theres a chance this wont be used but ive made it in a way it will also fit another bot i was planning next.
  4. #24
    Supermotolew
    Guest
    Fancied trying somthing new today, so had a play with modeling the hydraulics! Little slow@12v hoping to swap that out with brushless 6s
  5. #25
    Looks very, very cool. How heavy is all the hydraulic gear?
    FW: Azriel
    MW: Jibril, Kaizen
  6. #26
    Supermotolew
    Guest
    Each ram and hose + oil is about 440g these are about 30mm too long really so im adding a little weight in the claw to cope with the longer than needed geometry.
    The pump is a little heavier but i guess 70% of that weight is this big ol rs770-795 ish motor ( this or the spinner is what i plan for your motor to live ) should save weight and length!
    I think for "a hydraulic" pincer the system should be very light in comparison to other steel rams and dc packs. But for a feather weight its still heavy and my armour will suffer. Awaiting new scales and ill get u a total module weight!
  7. #27
    Hopefully yes, the motor should be ligher than a RS775 motor. I had to make this consideration for my Middleweight but if you are looking for modularity, design the weapon pod around the location of the motor as so to making dropping the pods in and out.
    FW: Azriel
    MW: Jibril, Kaizen
  8. #28
    Supermotolew
    Guest
    Hi Lucy,
    Wondering if you can help me ID this motor i thought it was a RS775 but now im wondering if its larger maybe a 895! or larger if they go!
    its 6.3mm shaft. body length 85mm body diameter 81.5 was in a 12v system.
    more importantly im looking for a brushless that would match it in torque and a little more RPM (i will run 5 or 6 s) and of course a little lighter!
    any thoughts?
  9. #29
    That sounds like a Speed 900 to me. There were Tornado 850s (I think) but the size of the motor and the shaft suggests a Speed 900. They are fairly uncommon these days.
    FW: Azriel
    MW: Jibril, Kaizen
  10. #30
    Supermotolew
    Guest
    Thanks it lools a little closer! How does one translate brushed specs to brushless equivalent? Im guessing not so simple!
Tags for this Thread
