Results 1 to 8 of 8
Thread: Designed for Demise: attempted antweight-in-a-day
    McMullet
    Guest
    We've been gradually accumulating bits and ideas for antweights over the last few months, with little to show for it, so Becky, Simon and I decided to have a day of building this weekend to chuck together something resembling a functioning robot. We arrived at the Hackspace around lunchtime yesterday with a sheet of 3mm polycarb, a box of HDPE offcuts and various electrical gubbins, and set to work. Here's my attempt!
    Weapon: servo-powered lifting arm
    Name: Twisted Lifter (pun on Twisted Sister, in keeping with the vague metal theme of our team)
    I had originally planned to 3D print a chassis, but figured it would be easier to bodge something together by hand for a first attempt, figuring that I can always just transplant the electronics and drive to a new chassis later if I like.
    With no real design in mind, I picked out a triangular piece of 5mm HDPE to use as the side panels and started work to fit in the N20 gearmotors. I didn't really have much of a plan here, just made each bit and then made the next bit, so after making the two side pieces identical in size and shape I drilled an 8mm hole all the way through both then spent a long time with a coping saw and a file making it into a 10x12mm rectangle. That was obviously not sufficient to hole the motor so I then made a face mount with some 1mm thick aluminium sheet and bolted it in place:
    Note the most mass efficient solution perhaps, and the weeny m1.6 screws interfere with the wheels when they're pushed all the way on (d'oh), but they're pretty solidly fixed in place.
    At this point I had two triangles of HDPE with motors attached, so it was a fairly straightforward job to stick polycarb panels on two of those sides. This is already visible in the image above, because I am slack at taking photos so I built half a robot then tried to take pictures of each bit.
    Originally I was thinking that I would spend yesterday doing the mechanical assembly of this machine, i.e., physically stick everything in place, then leave the electr(on)ics for another day. However, by about 5PM I was bored of drilling and sawing, and also had something that looked externally like a 2WD robot (albeit with no lid). Furthermore, without having some idea of where the wires were going to, it was tricky to visualise how the electrics would need to be laid out, so I figured I'd have a go at the slightly daunting task of soldering some wires to one of the DasMikro ESCs. This proved to be fiddly but not impossible.
    We then headed home and I plugged everything in to a battery and Rx, and twisted the ESC power lines around the motor lugs without soldering, just to give it a test drive. With a strip of electrical tape to hold everything down, in true sparky style, that gave me Twisted Lifter Mk0.9:
    After re-binding the Rx, it almost worked first time, to my not-inconsiderable surprise. One of the motors was wired in reverse polarity (or possibly I had the fwd/bk and L/R channels reversed), but that could be rectified by the extremely shoddy approach of holding the Tx sideways. I had a brief test drive around the lounge, which Simon filmed for posterity. I then handed the controls over for him to have a drive, and in keeping with Simon's recent driving record it immediately went haywire and caught fire. I'm kidding of course, it didn't immediately go haywire and catch fire, it went haywire after about 20 seconds and caught fire about 10 seconds after that, I shouldn't exaggerate.
    After legging it outside to avoid burning the house down, I initially thought that one of the hastily twisted motor wires had come loose and shorted out. However, there was no sign of any such issues and it seems like the DasMikro just decided to spontaneously combust (I understand this is a common feature?). Fortunately, the ESC was well clear of the Rx and battery, so the damage didn't propagate to anything expensive.
    Here's a charry ESC with some scorching to the motor:
    And a bit more detail of the motor:
    Still, I had fun driving this thing around for a couple of minutes, and the rest is still in decent shape. A few things I did note from driving and in general:
    • The 300 RPM motors with 35 mm wheels were a bit sluggish.
    • The machine is too long (12 cm) and not really the right shape (the long pointy wedge isn't really necessary for a lifter).
    • With all the components I need and no top panel I'm already close to 150g.
    • I was a bit concerned about the teeny lipo battery. Do people use fuses in antweights? I can't really find a suitably tiny fuse. Would a bit of fusewire somewhere be a suitable approach?
    • In a similar vein, do people usually bother with indicator lights in ants? I see that switches are allowed instead of links in the RW101 rules, and there's no mention of lights or fuses.
    To make it faster, I've ordered some 500 RPM motors which is an easy fix. Sorting out the size and weight is less obvious, but having something to start with helps. From the current design, I'll cut the pointy end of the chassis down a bit and mount the servo for the lifter in what is currently the rear panel (i.e., what currently looks like the front becomes the rear). That saves about 20g, which I can use on some more body panels and a lifting arm cut from polycarb. I may yet have to drill some holes to save more weight, but this is really just a first try so I'm not too bothered about butchering it (eventually I'm hoping to transfer the overall general shape to a cooler design, i.e., with more of a hair metal theme).
    In visual form, the red line is where I'll chop off the rear end, and the green line is where I need to cut a slot for a lifting arm to poke out:
    Hopefully this will be good enough to have a go at some competitions until I can be bothered with 3D printing! If anyone has any recommendations for less flammable ESCs that would be handy (we still have 3 DasMikro 2s6a ones knocking around, but I'm not impressed so far).
    Looks good, shame about the fire. Could always bring it to BotFest to see how it does.
    Fuses are not mandatory as you have read but if you have the weight, recommended. Lights are also not mandatory but I'd recommend them as well in some capacity. I would recommend perforating the polycarb and HDPE in specific places to lighten it.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
    McMullet
    Guest
    It's fine, no harm done and better to find out the DasMikro is a bit dodgy now than at an event or something...
    I would definitely prefer a fuse but I'm struggling to find something suitably small. I did wonder about using a PTC resettable fuse instead, as that can be wired in permanently which saves some weight. Not sure how normal a solution that is though.
    Botfest is in my sights, hoping we'll have something ready by then if we can make it!
    As far as I know, it isn't "normal" but if it works, it can be used so there isn't a reason I can think of why it wouldn't work so long as it does the job of being a fuse.
    DasMikros, as you may have seen on the RW101 forum, can be a bit patchy in terms of overall quality. Most are pretty good, some aren't. Luck of the draw I guess.
    FW: Azriel
    MW: Jibril, Kaizen
    McMullet
    Guest
    I've made a bit of progress on Twisted Lifter during the lockdown. It's a good motivation to get our "workshop" (i.e., a 4' workbench in the back kitchen) tidied and I finally got around to buying a decent soldering iron. One of the few silver linings in being stuck at home is (for me at least) an increased willingness to just get on an bodge things, since it's less easy to go out and buy tools and so on.
    I proceeded with my plan to reverse the whole robot and cut off the newly defined rear end, creating a much steeper front wedge. I then cut out a lifting arm (combination of coping saw and dremel work), secured it it insecurely to a servo and then cable-tied the servo in place. Et voila:
    I chucked everything in together and the weight wasn't a million miles off:
    Part of that weight comes from having a Spektrum AR610 Rx in there with a plastic case, so I ordered one of the newer Lemon top-pin Rxs to save a couple more grams. That turned out to be quite a rabbit hole; for some reason, the new Lemon Rx just wouldn't bind to either of our Devo Txs. I tried updating the firmware, rolling back the firmware, binding in "Orange Rx" mode, going out in the garden, DSM2 protocol, etc.... There's definitely something weird going on there, because I have two of the new Rxs and they work fine with the Dx6e Tx, both Devos work fine with other DSMX Rxs (Lemon, Orange and Spektrum) that I've had for a while. Something to watch out for if you have a Devo Tx and Lemon Rxs, possibly, I don't know. Anyway, I eventually gave up and will have to exclusively use the Dx6e for now with this robot.
    The lighter Rx did help, in any case. With no holes drilled out, and a random chunk of plastic bits, I'm pretty much bob on the weight limit:
    I had another couple of happy minutes driving this around before another DasMikro went up in smoke. I think I'm going to give up on them and get one of the BBB ones (or the ones that BBB sell only from eBay, if they don't have any in stock for a while).
    McMullet
    Guest
    New ESC arrived and wired in, and in a spectacular development DOES NOT catch fire.
    Just need to put a lid on this now.
    Question: do folks generally wire resistors across their motors to get a bit of centre braking? I was struggling a bit with constant spinning, although that's a common feature of my driving.
    No fire is a good fire. :P
    I don't put resistors on my Ants. I guess fitting them won't add too much weight so probably worth doing if you feel it is necessary. I find my ants can be quite excitable under fast driving but I've gotten used to the fast and furious nature of driving them.
    FW: Azriel
    MW: Jibril, Kaizen
  8. #8
    McMullet
    Guest
    I'm more concerned with the faff of soldering than the weight, to be honest - not really sure where I'd fit them in now without making a terrible mess! I might leave them off for now.
