Just a heads up, the newer Mylek Compakt drill has slightly different motor/gearbox - the motor mounts still fit ok, but fitting the ball bearing ring in the end can't be locked in with the circlip. At the end of the month I should be able to give it a test drive to compare the speeds between old and new.![]()
