Results 1 to 10 of 19
Thread: My first beetleweight build - some newb questions to follow!
Hybrid View
    Ocracoke's Avatar
    Team Kaizen
    I have xt60 connectors and so could use them. Does it have to be able to be removed by hand? Does it have to protrude from the bot? Anyone have a pic of one in use?
    Yes, it must be removed by hand (no tools allowed) and yes, it can protrude from the bot though in that instance, I typically have them on the top of the robot. If you recess the connector in a little further into the robot, that will help with the loop of wire not being as exposed.
    BW: Shu!, The Honey Badger
    Joshua
    Guest
    Sorry about hijacking this old thread. Just to check (which I unfortunately believe is the case from rereading the rules and this thread) Whyachi-style switches are not acceptable under FRA rules, the only acceptable way to power on/off a robot is a removable link that does not require tools to active/deactivate, but could be hidden beneath a panel that is toollessly accessible i.e. a latch or velcro?
