Results 1 to 4 of 4
Thread: Electric Hammer/axe
    is my test of my mech, will find some pics too
    Mine is a 2 stage chain running to about 6:1.
    Sadly this was due to space constraints with the shape of the robot.
    Motor
    9:14
    36:9
    AXE>>>>>>>>
    will confirm soon
    Later swapped out the drill motor for a scooter motor but the layout remained pretty much the same.
    Axe arm bolted on to the large sprocket, ran on a speed controller and I just pulsed it to control the swing and not over-swing/hit the chassis.
    Ampflow F30-150 connected to a MOD 1.25 20T pinion gear, going to a 70T and then a 20T to a 90T final output gear which the Scythe axe is bolted to. This results in a 15.75:1 ratio. This setup isn't ideal as it has little shock resistance. A chain drive like Jamie and Nat's have as a final 3rd stage reduction would be preferable.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
