Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Team Pushover: Build Log
  1. #21
    Scarrosaki's Avatar
    Roboteer
    Status
    Offline
    Name
    Jon A
    Robots
    Bodacious Fyraan-Gaaris (AW), 2 Bodacious 2 Spurious (AW), Thunderpants (BW), RCS (FW thwacker)
    Location
    Chester UK
    Posts
    27
    If no luck on the Devo7e, I'll be bringing a second one with me. If you want to use that one, be my guest
  2. #22
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Pullover V2 (AW), Leopold (BW) & 1/3 of a Feather (Pushover)
    Location
    Gtr Manchester
    Posts
    148
    Awesome stuff Scarrosaki, really appreciate the offer, obviously i’d Like to get my own working because Pullover is as yet untested, I don’t even know if it works
    Feels good to have a backup though, cheers my guy!
    Team Pushover - Definitely worse at this than you are!
    AW - Pullover, Wej
    BW- Leopold
    FW- Pushover (well, half of it...)
  3. #23
    Scarrosaki's Avatar
    Roboteer
    Status
    Offline
    Name
    Jon A
    Robots
    Location
    Chester UK
    Posts
    27
    Quote Originally Posted by Retroman View Post
    No worries dude, give me a shout at the event if you need it and we'll see if can get it running. If you've got a bind plug though bring it, as there's a good 70% chance I'll have lost all of mine
  4. #24
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Location
    Gtr Manchester
    Posts
    148
    Funny enough, the bind plug is currently plugged in...
    If I have to wait until event day, I’ll have to manage, it *looks* like it will work, and it’s within size (same body shell as last time) and only about 130g minus 2 screws... so it passes every check except the figure-8 right now
    AW - Pullover, Wej
    BW- Leopold
  5. #25
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Location
    Gtr Manchester
    Posts
    148
    So after narrowly averting disaster with the Devo 7e (I wiggled the power switch ) we now have 2 fully functional ants again!
    Pullover weighs in at a hefty 129g ready to fight, I'm thinking of adding a scalpel blade to the grabber for grip and some putty for ballast under the nose, but that's all we'll need I think. It currently can wheelie on command and rocks back right up onto the rear wedge section, without the undertray it actually flips itself up onto its rear .
    specs: 2s 330mah LiPo, NanoTwo, Lemon RX, Vex29 weapon controller, 700g+ (part charged atm) force at grabbing tip, still too fast for my terrible driving.
    DerpWej is slightly porkier at 143g and now its stopped tearing its lifter motor off is also 100% fighting fit... if ugly as sin...
    Specs: 2s 330mah LiPo, eBay antweight dual ESC, flysky rx, can lift 750g
    Both fit (just) in my 97mm build cube, so breathing room for tech check.
    Not as neat as last time, but also not wired up backwards , 1st pic is Pullover on left, DerpWej on right. Pic 2 is the underside of Pullover showing the ridiculous 65x55x25mm space I wanted to cram everything into, because I'm silly.
    AW - Pullover, Wej
    BW- Leopold
  6. #26
    Scarrosaki's Avatar
    Roboteer
    Status
    Offline
    Name
    Jon A
    Robots
    Location
    Chester UK
    Posts
    27
    Awesome, looking forwards to fighting them!
    How's Pullovers weapon working now, iirc last time you were having problems with some horrific lag on it?
  7. #27
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Location
    Gtr Manchester
    Posts
    148
    Ah yes, that lag was... interesting...
    i timed it when I got home, from pressing and releasing the stick it was 0.6 secs to move and almost 1.4 to change direction, but now it snappy and responsive, so much so that I want to add a dead band to make it less twitchy, good power now too.
    I seriously question whether DerpWej is even remotely competitive, I think our front angle is a little steep, but it pushes like a tank.
    anyway, bring it on! I’ve lost to you before, I’m sure I can lose to you again
    AW - Pullover, Wej
    BW- Leopold
  8. #28
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Location
    Gtr Manchester
    Posts
    148
    Botfest 3 today, and mixed results for Team Pushover...
    Pullover performed very well, let down only by the nut that was holding the controls . On out 3rd attempt, we finally scored (lucky) win against Bodacious Fyraan-Gaaris, and went on a good run managing to beat a few others, although lost to both Voodette, and Janet Street Porter. Ended up out in the heats but finally seem to have the robot working as it should, except when it died randomly - never just works well does it? So I have a loose connection and a dodgy power switch on the Devo.
    As for Wej… well... it's going in the bin. It. Was. Terrible. I managed to be embarrassingly and overwhelmingly beaten by almost everything, I did score 3 points after Psycopathy (I think) gave up. Turns out we have some serious design flaws, with the arm down it was too narrow to push, the arm itself had to be shortened for the box and ended up too steep, and with the arm up it wheelie'd everywhere and left enough room under the front for a small car to park up. Pants.
    Also shout out to Kev with Spinnahhh, I fitted a bulldozer scoop to Wej for the rumble, which he proptly chewed off, followed closely by the wires to the weapon motor!
    There are plans afoot however, find the loose connection on Pullover, fix the Devo, replace Wej (Spinner perhaps?) and crack on with Pushover and see if we can't have something to display next time.
    Enjoyed my little self though!
    AW - Pullover, Wej
    BW- Leopold
