Results 11 to 20 of 28
Thread: Team Pushover: Build Log
  1. #11
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Pullover V2 (AW), Leopold (BW) & 1/3 of a Feather (Pushover)
    Location
    Gtr Manchester
    Posts
    148
    Yeah we had no smoke, and the fuse went instantly so no time to get hot, I should have the time spare tomorrow or Monday to find out... I wonder if they're in stock... you know, just in case.
    Team Pushover - Definitely worse at this than you are!
    AW - Pullover, Wej
    BW- Leopold
    FW- Pushover (well, half of it...)
  2. #12
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Somewhere on the Wirral
    Posts
    1,003
    From a conversation I overheard at Ant Freeze 6, no. The problem is that the receiver used on the NanoTwo is not in stock at the moment. If you contact Rory on here, he might be able to shed some light on that.
  3. #13
    James Williams's Avatar
    Roboteer
    Status
    Offline
    Name
    James Williams
    Robots
    Neophyte, Meteorite & Exabyte (FW)
    Location
    Birmingham
    Posts
    101
    A quote from Team Nuts's facebook.
    The NanoTwo V3s were forcibly discontinued when the small OrangeRX receivers which they were based around disappeared. Many other DSMX/2 RXs are also being discontinued at the moment, so to avoid all that, the NanoTwo LT is essentially a NanoTwo V2 (which was a cheaper and more reliable design than the V3) with servo leads attached allowing you to use your RX of choice. This should work well for many BBB teams looking to upgrade their kits.
    They will be appearing for sale soon. Since the bulk of the manufacturing has been done already, stock levels should also be more reliable now.
    James
    Team Phyte
  4. #14
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Location
    Gtr Manchester
    Posts
    148
    Boom! Cheers James, I'm not on Facebook anymore so I hadn't seen That, good to know... and hopefully I don't need one quite yet anyway... valuable to know though.
    Ang while I'm on, quick teaser for Wej, a polycarb front hinge flipper with a target flip of 350g at the top most extremity, if I can get my set up to work fast enough I *should* be able to launch another ant pretty effectively, it's purely experimental at this stage but looking reasonably positive, pictures as soon as it's worth looking at!
    AW - Pullover, Wej
    BW- Leopold
  5. #15
    Roboteer
    Status
    Offline
    Name
    James Williams
    Robots
    Location
    Birmingham
    Posts
    101
    Don't blame you, I'm not on there either. I only saw that by chance as I was looking for info about the next BBB event. Even if you don't need one yet I'd still grab one as soon as you can, each batch sells out within hours & it's usually several months between batches. If I remember I'll leave a message on here next time I notice they're available.
    James
    Team Phyte
  6. #16
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Location
    Gtr Manchester
    Posts
    148
    In all honesty that's how I got the one I have, it said in stock so I just bought one ha. Cheers for keeping an eye out too!
    But yeah, that faceache thing is toxic...
    AW - Pullover, Wej
    BW- Leopold
  7. #17
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Location
    Gtr Manchester
    Posts
    148
    IT LIVES!!!!!! sort of...
    Reversed the polarity and pit it back how it should be, and everything kind of works, the Vex29 is snappy and responsive, the grabber moves faster than I thought it ever would and it grabs with 750g or pressure at the tip, I'm delighted!
    But now for the kind of, the NanoTwo didn't seem to survive so well, it's obviously receiving and processing the signals, but the motors will barely spin even with full stick movement, and I *think* it was beginning to get warm... damn...
    AW - Pullover, Wej
    BW- Leopold
  8. #18
    Bad Wolf's Avatar
    Roboteer
    Status
    Offline
    Name
    Bad Wolf
    Location
    North Wales
    Posts
    96
    Glad its kinda of working mate! Fingers crossed its saveable!
    Im re-thinking my orignal idea of making an Ant weight version of Bronco, but this time Im going to have it printed out instead of making it the size and weight of a ugly tank haha
    Bad Wolf
  9. #19
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Location
    Gtr Manchester
    Posts
    148
    Mmm... I think the NanoTwo is toast if I'm honest, I might try and get hold of Rory through the week for a professional opinion.
    Just been checking out the CAD in your post, looks good, what internals you going to be using? Sticking with 4wd?
    AW - Pullover, Wej
    BW- Leopold
  10. #20
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Location
    Gtr Manchester
    Posts
    148
    So, no update for absolute age, sorry. Team Pushover has been at a standstill over the summer, this being a responsible adult keeps getting in the way.
    Pullover is now on version 4, and I was hoping that at Botfest I could throw it in the arena with everything 100% working (previous 2 versions have all had some pretty serious weapon issues)… but even now it. wont. work. Having replaced the cooked NanoTwo with the latest version and a new receiver, my Devo 7e has decided to spit it's dummy out instead... great...
    Wej the experimental front hinge monstrosity is hiding on a shelf as my building abilities and available materials can't get it below 212g whilst being stable enough to stay in one piece, so it's replacement entry for Botfest will be DerpWej, a hideously ugly and poorly build lump with a monster lifter.
    As the 2 previous events the "Flagship" of the fleet is the better made of the 2, but suffering from electrical gremlins again. and the thrown together heap works beautifully. I'm spotting a pattern.
    Pushover; The team mascot is now more than a box of parts, a 6mm aluminium base with aluminium angle armour supports sits proudly on the work bench, the flipper arm (paddle?) is also present, HDPE sides are cut but undrilled as yet, and the left hand drive motor has seized it's gearbox. So we have an immobile space frame of 6mm alu and 18mm HDPE that looks halfway decent, remember that pattern I was talking about? yeah...
    Pics of Pushover soon once the sides are drilled on mounted.
    AW - Pullover, Wej
    BW- Leopold
