Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: Editing posts
  1. #31
    McMullet
    Guest
    Sad times.
    Forums generally have died off a lot over the last 5-10 years, which I personally think is a shame, but there's definitely still a place for them in niche areas like this.
    It seems like the FRA needs to exist in some form, how else are the rules going to be kept harmonised between events?
  2. #32
    kane's Avatar
    Roboteer
    The errors should be fixed now. There was a PHP version mismatch causing the issue.
    If you encounter any problems, simply email info@fightingrobots.co.uk and try to include screenshots where possible.
    Kane Aston
    http://www.makerobotics.com
    Co-owner and builder of BEHEMOTH
  3. #33
    Many thanks Kane, I've tried quickly editing a post and the image popup. They both now seem to work, will try more fully later.
    And indeed, editing posts does seem to work now.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
  4. #34
    I've noticed this issue has cropped up again. I've e-mailed the FRA to see what can be done.
    FW: Azriel
    MW: Jibril, Kaizen
  5. #35
    fra's Avatar
    Administrator
    Hi Lucy, thanks for pointing this out. I've fixed the issue for now and will look into a more permanent solution.
  6. #36
    Many thanks, I see it is working again.
    FW: Azriel
    MW: Jibril, Kaizen
