Results 1 to 6 of 6
Thread: Gearbox advice
    It certainly is possible to mate the motors with the gearboxes but you'll likely need to find a pinion gear for the motor and make sure that the mounting holes in the gearbox fits onto your motors.
    Yeah, RC car stuff at this level will strip fairly quickly (as do some drill boxes I have to say, try and find ones that are all metal if you can). If you had the time, you could build your own 1 or 2 stage spur gearbox but that can get fiddly.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
    Al_'s Avatar
    Member
    If you can tell us if they are old style or new style Argos drill motors, it might be worth a post in the wanted section too. Someone might have a gearbox or 2 left over after just using the motors from the drills for spares?
    Gimsons are a option but they are not cheep either and you can find the same boxes cheeper from china but it depends on how quickly you want it
Tags for this Thread
