Page 27 of 28 FirstFirst ... 1725262728 LastLast
Results 261 to 270 of 279
  1. #261
    Ocracoke's Avatar
    Team Kaizen
    Thanks guys. If there was space this weekend, I'd see if I could make that but I doubt there is.
    Took Azriel for a run in the garden, managed to break the axe, a drive motor and the other drive motor is burning out (given it is from Kaizen, that isn't totally surprising). Will be mending tonight.
    Jibril's motor is now fitted to the carrier but the first stage output gear doesn't fit the carrier without either a new final stage gear that is bigger or an idler gear. Simply for the increased torque (and thus, more force to self right with), I may get a bigger gear.
    BW: Shu!, The Honey Badger
  2. #262
    Ian did say that there was one spot left the other day. If you really want to, it wouldn't hurt to email him, explain your situation and see what happens.
    James
    Team Phyte
  3. #263
    There was a sportsman drop-out I believe but I think it filled back up again very quickly!
  4. #264
    Shooty's Avatar
    Roboteer
    Just checked the dojo chat. Another spot has opened up if you're still up for it.
  5. #265
    Would be a shame for Azriel not to fight after all the work you've put in. You should definitely sign up if you can!
  6. #266
    Ocracoke's Avatar
    Team Kaizen
    I read Jamie's reply as being that the space had filled up again. I'll wait until the next Dojo to see what the situation is here before committing but yes, it sucks that Azriel can't go.
  7. #267
    I think Eoin was referring to another space being available. I know who filled the space Jamie was referring to, so the dropout that Eoin is talking about will be someone different
    Can't harm to at least sign up and try?
  8. #268
    Ocracoke's Avatar
    Team Kaizen
    Sorry to say, I can't go due to stuff here.
  9. #269
    Ocracoke's Avatar
    Team Kaizen
    OK... so BotFest has meant I finally have a reason to look at my antweights. Ikari and Amai are fine and ready to go (barring a small repair job on Amai). Osu is fine as well but as I mentioned in a previous post, it has been retired from combat. However...
    Lafiel
    It feels like ages ago but back at Ant Freeze 7, it was practically demolished. It was held together with sellotape but it really is time to rebuild the shell. This is, at the moment, an all polycarbonate affair with custom polycarbonate brackets to hold the panels on with. I tried this originally with HDPE blocks but I feel the polycarbonate is better for this. The shell is a little big and heavy at the moment but I'll sort it out.
    The spinner motor I am looking to change back to the original one I had planned in the form of a Turnigy AX-2204C 1450Kv which I am sure is lighter than the Surpass 2204 1200Kv motor currently fitted.
  10. #270
    Ocracoke's Avatar
    Team Kaizen
    Lafiel
    So the shell I posted a picture of in my last post didn't work. I could, amazingly, get it in size and weight but it was quite ugly and it wasn't very good overall so I ripped that apart and rebuilt the shell again and here we are with the 1.1 version. It needs some narrower wheels to accommodate for the fact that it is ever so slightly wider than the 1.0 version.
    Early testing of this worked OK but then the spinner motor seized up because of a circlip on the shaft catching. Ever since then, when it spins up, it gets to about 70% power and then it starts becoming unstable. Why this is I am trying to determine but it is essentially ready for an event when one is able to run.
    Next one on the list to rebuild is Shu!
