Page 24 of 38 FirstFirst ... 14222324252634 ... LastLast
Results 231 to 240 of 373
Thread: Team Kaizen Build Diary
  1. #231
    The axe I've deliberately not painted as that is only a temporary affair until I can find someone able to cut a all metal one for me
    What material and specs? Happy to fabricate one if I've got suitable stock.
  2. #232
    Quote Originally Posted by RogueTwoRobots View Post
    I'll PM you as soon as I can.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
  3. #233
  4. #234
    Ooh, I wasn't made aware of this. If there is one on and there is room and it is safe to do so, yes, you'll see Azriel there. How do you sign up?
    FW: Azriel
    MW: Jibril, Kaizen
  5. #235
    Mr Manuva27
    Guest
    They only announced it on Facebook last night.
    Link to the post. Signup doc is linked in there .
  6. #236
  7. #237
    Excellent. I've signed up for Full Combat (as that is what Azriel is built for).
    FW: Azriel
    MW: Jibril, Kaizen
  8. #238
    Jibril
    So the original plan for Jibril was to use a A28-150 motor running through a 23.39:1 gearbox for the Scythe. I've then come across, and bought, a A28-400 motor for the straight up power upgrade. The A28-150 motor can go into Azriel after Dojo.
    At this stage, I really do need to learn how to drive a set of relays for backwards and forwards motion on the axe rather than use a speed controller, does anyone have a diagram of what is sometimes known as a "bang-bang" controller?
    Azriel
    Material for a front wedge plate has arrived so will be fitting and bending that over the next weekend, I understand Full Combat in Dojo can be quite violent (not that I don't think EXR events can be as well). I don't have the facility to make a metal one so HDPE it is.
    Shu!
    I've been thinking hard about wherever I want to continue with Shu! since its appalling performance at the BW championships. Ultimately, I am going to make a v3 as v2 never really got a fair outing, the speed controller exploded before the event so it could only go forwards and backwards.
    Since it is a fun design, I am going to take the Ikari design and modify it for the BW class.
    FW: Azriel
    MW: Jibril, Kaizen
  9. #239
  10. #240
    SSRs is something I've thought about using but as far as speed controllers go, the problem is the amperage. The speed controller that drives it at the moment is a 80amp peak and the motors that drive the axe can easily ask well over 200a, especially on the strike. The other thing I am considering is that during the swing, on a speed controller, it is too slow. A relay should in theory solve that as well.
    FW: Azriel
    MW: Jibril, Kaizen
