Page 15 of 38 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 373
Thread: Team Kaizen Build Diary
  1. #141
    Jibril
    So I didn't get a chance to work on the Scythe on Sunday but over the last few evenings, finally the Scythe is back together!
    The new mount feels way more solid than the original one. The gears themselves are marginally less meshed than the last go around so in theory, it should swing easier. Definitely felt like it will. Annoyingly, the 1st stage output gear is still slipping on the shaft so I need to get the screws out, drill the shaft with indents for the grubs to sit in and then put it all back together. Ideally, I should drill all thy way through the shaft or key it but as this version is being "retired" as an axebot, I only need it to last EXR Colchester.The slipping drive grub screw has been replaced with a new one and threadlocked so it shouldn't fail again.Tomorrow is battery charging, reassembly and testing hopefully before being transported for a 5 hour drive to Colchester one way.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
  2. #142
    Jibril
    The robot is back together and on the trolley, the drive looks fine and will run on Saturday. The Scythe is another matter. It runs but the 1st stage output gear is slipping badly. Now what I think is happening is that the flats on the gearbox shafts aren't flat enough and/or are in the wrong place so the locking grub screws are just sliding on the round shaft. I know this technique works because the 2nd stage pinion has this and that does work - it hasn't moved.
    I can't work on the robot on Friday, I desperately need sleep so I can get up very early AM on Saturday to be on the road to get to Colchester before the show starts. So yeah, that is going to be fun getting the gearbox dismantled, worked on and then all back together before the show starts (I jest, this is likely to take about 40 minutes to do). I need to get some long reach Allen keys and it should be fairly obvious where to make the flats.
    FW: Azriel
    MW: Jibril, Kaizen
  3. #143
    Jibril - EXR Colchester
    Another one of those long drives again. Took 5 hours getting here and as near as makes no difference 10 hours getting home. I got diverted from the A14 onto the M25/M1, then an accident on the M1 blocked everyone up and then the M6 between junction 14-15 was shut too. Like Portsmouth and Burgess Hill, this is one of those "all weekend or nothing" events for me.
    Got to Colchester and setup on a table. In terms of MWs, we were only having whiteboards this time so in with You Little Ripper, Backlip and Gaston. Anyway, got ready by threadlocking the output gear on the 1st stage and fiddling with the TX controls to limit the end points. The hope was that it would resolve the control issues I have been having with this robot.
    The first fight proved the basic idea of the end points worked. It wasn't wheelspinnng as much, a little too much, turning felt too slow but the forwards/backwards motion was OK. What wasn't was the Scythe. I did a test beforehand, Sycthe moves. In the arena, nothing. Got lined with Gaston, nothing. Then I got flipped and you know how this goes by now. Ended up being flipped OOTA by You Little Ripper.
    The damage was as follows:
    • The Scythe gear shaft was bent in two places. Ended up having to cut the shaft to get the gear off. The new mount held up though.
    • The grub screw I replaced on the drive fell out so lost drive on one side.
    • My hopes and dreams. :S
    After a bit of time to cool off, found a replacement threaded shaft, cut the old one up and rushed to get the new shaft mounted. Managed to get it on just before the show started along with the drive again. I readjusted the end points again but alas, the Scythe still wasn't firing. I spotted that the gears were not meshing and despite repeated efforts, it wouldn't mesh.
    The second fight went better. With no weapon, I rammed Gaston several times, taking a few blows from the spinning disc. Backflip then flipped me onto my back and tried to right me. In the end, this worked but then one of the battery leads fell out. Now, if this was a single battery to the weapon or drive, this would be "better" because it wouldn't affect the other circuit. However, these batteries are in series driving both the weapon and drive so when the lead came out, it killed both.
    Still, Jibril wasn't as badly hurt as the first fight. The Scythe came out relatively intact and once the lead was reinserted, the drive was fine.
    I'll be bringing this robot to BotFest 3 along with the frame for Jibril 2.0. The only change I might make is to increase the bore on the mount to drop the output gear down a little so it meshes properly. After BotFest 3, the internals of this 1.3 version is being moved to 2.0.
    FW: Azriel
    MW: Jibril, Kaizen
  4. #144
  5. #145
    Thanks Colin. The last major drive is to EXR Maidstone but that is not for a while yet. Got Marlow for the BW Championship the weekend before as well but thankfully not going solo to that. I'll have to see if I can get the time to go to Dojo again, might even be able to compete next time :P
    After BotFest 3, it is the big move to get everything into the new shell. I've also decided to completely rebuild and redesign the axe mechanism and Scythe after what happened at Bolton and Colchester. Taking the gears to MOD 2 and when I looked at it, the ratio I can get to is something in the region of 20/24:1. That with the A28-150 motor, which is 3HP at peak should translate into a more "effective in theory" mechanism.
    The Scythe will have a new shaft which will move the pivot point a little further up the shaft to permit a counterweight and reduce a little bit of stress in lifting the 3.5kg axe head.
    FW: Azriel
    MW: Jibril, Kaizen
  6. #146
    McMullet
    Guest
    That is some dedication to do all that driving for a couple of fights!
    Always a pleasure to read your event reports, Lucy. Sorry it didn't work out especially well (especially the trip home - I think I'd be far angrier about that), but sounds like you've got the bugs figured out!
  7. #147
    I've got the driving sorted but the Scythe... nah. Now that BotFest 3 is out of the way and people have gawked at the... brokenness of it... the robot is going to be gutted down to the shell. The new build will solve a lot of the issues this one has been seeing but first, I really do need to get Shu! sorted first. That is half sorted, just needs a front panel and wiring sorted.
    Oh, I also need to replace a motor in The Honey Badger 4.0 despite it never having been in a fight. Looks like I had a bad batch of MFA motors come through or I damaged them in a 4WD beetle test ages ago (probably the latter).
    FW: Azriel
    MW: Jibril, Kaizen
  8. #148
    Shu!
    I've finally got some time to work on this one. It is being completely rebuilt since the last one met it's fate at the last BW championship. Featuring 6mm HDPE and 4mm polycarbonate with 30:1 MFA motors, it should hopefully prove more durable than the last version (PVC does not make good armour). The drive is now operational and I should have a video of it moving around for proof of mobility by tomorrow.
    The weapon remains the same, a nice bit lifting arm but although the mechanism is fine, the wiring isn't. Got it wired and and put the removable link in. Next thing I know, smoke and heat. Couldn't get the link out so I yanked the battery out. Got a nice blister and a couple of scorch marks on my fingers for that. So that is a new weapon wiring loom in need now.
    FW: Azriel
    MW: Jibril, Kaizen
  9. #149
    Shu!
    Spent a bit of time fixing the weapon arm onto the body and then filming for the proof of mobility. Obviously not finished yet but it is getting there. I also misspoke in the video, not the UWE but the BW championship.
    FW: Azriel
    MW: Jibril, Kaizen
  10. #150
    The Honey Badger
    Oh yes, it is back but perhaps not as you remember it. It has technically been ready since March-ish time when there was an event planned in Shrewsbury but I've only just replaced a damaged gearbox on the drive, so here it is. I may still fit a self righting servo onto this one, need to weigh it accurately to see what is left.
    FW: Azriel
    MW: Jibril, Kaizen
