Results 1 to 8 of 8
Thread: Replacement gears for GLA1800 Linear Actuator
Hybrid View
    Oh I wasn't meaning the gears. I meant the whole linear actuator unit. You would be unlikely to find the gears as they will likely be made specifically for that actuator.
    Ah right. Sorry for late reply, notifications for the wanted section are a little busted. I'll take a look on Aliexpress. Can't find the name Gimson popping up, and searching for the 1800N rated load gives nothing either, so I'll keep looking at the mechanisms in similarly rated actuators, unless there is a better way of searching.
