Results 1 to 4 of 4
Thread: Spektrum DX7S mixing
    If you've enabled elevon mixing on the TX for forwards and backwards then it should just "work" for side to side motion. I have known instances where if the TX has mixing enabled and ESC has mixing enabled, that can have unusual outcomes though I am guessing there are two separate ESCs in play here, one going into the AIL channel and one going into the ELE channel?
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
    You have two mixes go on in the same TX? I did that once in my OrangeRX system I seem to recall which led to a lot of odd stuff going on.
    In the end, I only needed Elevon mixing enabled. I would turn off all mixing in the TX and then set the wing type to Elevon and see if you can set AIL > ELE (I think) on the mixing screen. I think that might help though I must confess, I don't have a DX7S so can't verify that.
    FW: Azriel
    MW: Jibril, Kaizen
