Results 1 to 9 of 9
Thread: Chain Drive
    As far as I'm aware that should be the case. If you want to see a drive system more in depth Matt Maxham has a brilliant video diving into his bot Sewer Snake, and it shows off his drive system, which has to be one of the most effective ever built in robot combat:
    I'm not an expert on reductions, but Craig Danby once said to measure the diameter of the wheel in inches, add a couple more, then that's your reduction. Was a while ago, but it's a pretty reliable rule of thumb
  8. #8
    Triceratop
    Guest
    Hi, just thought I'd throw my two pennith in.... stay away from #25 chain (mini moto). The chain is very strong and sprockets quite small due to the pitch but the chain is not forgiving on misalignment - as I found out. I would suggest a form of tensioner even if it lays on the chain, that will help keep the oscillation down which if left can result in chain jump off the sprockets.
  9. #9
