Results 1 to 6 of 6
Thread: Argos drill motor mounts and other mounts.
    Still in manufacture (September 2019) Made to order and usually ship next day.
    Cost is £7 a set for 1 motor. Postage Starts from £2.50 and depends on weight/quantity ordered.
    I can also change dimensions of mounts should your design require it!
    Height from centre shaft: 30mm
    Distance of mount holes 52.5mm x 30mm. Press the mounts firmly together to check your spacing measurements.
    Mounting bolts: M5 depth 20mm
    I can also design mounts for other motors, and have done for Bosch motors.
    Have something odd? I can discuss postin the motor to me and I can 3D scan the motor assembly to produce bespoke mounts.
    Just get in contact :-)
    Thank you,
    As an update, i have now 2 designs of mounting options with using the zink screw inserts for M5 bolts, and another design for Barrel nut or Cross Dowels for M6 mounting screws, see image.
    I can also adjust the heignt from axle centre to base should your design requirements necessitate it.
    A video of the fitting is on YouTube.
    Or google Argos motor mount YouTube.
    I ordered 4 sets of these mounts, from order to delivery, just a few days. Thank you Roboteernat.
    I have to say they do their job really well, and are certainly well designed to keep the new*er* Argos drill/gearbox units together and secure. Bye bye to the bodge of holding the motor to the gearbox via some electrical tape!
    I will be ordering more sets of these in the near future.
    Just to say i have now got back after getting married, so can now accept orders for motor mounts, wheel hubs and wheels combos.
    I will also like to add that i have a design to suit the Black and Decker motors with the 3 screws around the gearbox. These have the same mounting holes as the argos ones, so would be compatible with argos spacings.
