Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Featherweight build
    There is the featherTwo by Shakey, but there are programmable ones including hobbywing escs and the good ol TZ85A. Sadly the TZs are discontinued.
    Triceratop
    Guest
    Hi all, I am also starting my first build Featherweight, can anyone recommend drive motor size please? Looking at two axles with one motor to each. Also what sort of min speed should I be considering for the robot in the arena?
    Many thanks
    Drill motors are a good place to start since they come with the gearbox already attached. There are alternatives, such as the Gimson 13.7:1 motors I use in The Honey Badger robots, which are based around the "775" motors, gives decent speed and power for the size.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
    Would these batteries work?
    https://hobbyking.com/en_us/zippy-co...pack-xt90.html
    I'm building a simple wedge and would also like to know if these are ok, would one do it or should I run two or more?
  8. #8
    Those are way too big for a FW
  9. #9
    Quote Originally Posted by Anttazz View Post
    for drive they are pushing it for brushed motors, for weapon there is no such thing XD
  10. #10
    assuming your wanting to run these motors for drive - 2 axles, then thats 5.4kg with just the motors not to mention gearboxes
