Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: FW electric crusher build
Hybrid View
    Hello everybody, I am planing to build a new feather weight crusher for live events later this year. To start with I have began designing the crushing mechanism and will build the rest of the robot around it. Currently a 24V Linak 6000N linear actuator is being used to power the weapon.
    Spec of the actuator:
    Here are the CAD drawings of the mechanism:
    The claw will be 10mm thick steel, and the mounts 20mm thick HDPE.
    For the setup and holes used in those examples these are the performance calculations:
    Effectively the jaws open 225mm high and 60mm low, with close to 4000N of tangential bite force across the whole movement. The vertical bite force is lower at start of the cycle but ends up at 4000N at the end of the cycle, this is not so much of an issue as this force will only be used after the tangential force has pieced the armor.
    Anybody with more battle experience be able to tell me if i have enough force and bite width to be effective with this set up?
    To continue the design I plan to use a low tornado like body in line with the weapon mounts 130mm high and four wheel drive drill motors. I would ideally like it to be capable of self righting but i'm struggling to think of a way that wouldn't involve massive wheels or a heavy powered solution.
    I though about roll bars but i'm worried the heavy actuator would give it a poor center of gravity for self righting as its mounted high in the robot.
    Al_'s Avatar
    Member
    Hi, and welcome to the forum. I have a FW hydraulic crusher so I'll have a stab at answering your questions.
    225mm jaw opening will fit most featherweights in it. There will always be the odd one or two too big to fit, but it you go chasing every last one its not worth the trade off in increased weight or less crusher effectiveness.
    Does it have enough bite force? Impossible to say really. As before there will always be bots you can't crush and there are so many variables such as different armour types, thicknesses, where you grab a bot and so on. Put a good drive system on it and at worst you have a crusher for lightly armoured bots and a capable control bot for the heavier armoured stuff. More crush is always good but you'll add weight to yourself to make sure your own bot can take the forces too, and crushers have to be very sturdy to do this to begin with. Are the 20mm HDPE bulkheads going to be up to this?
    Just as important as the amount of crushing force, I would say is the speed at which the crusher closes. There is no point having the most powerful crusher if you never get to use it on anyone.
    I would also suggested you think about at least some form of self righting, you will end up flipped over at some point. Also, try and get a good estimate of weight for the whole robot before you start, it disappears fast.
    Please don't let that put you off, crushers are an ambitions bot for a first build. (It's your first post, I'm guessing it's your first bot?) It's always good to see another crusher in the works!
    Al_'s Avatar
    Member
    I would think that the 10mm steel would be thick enough for the claw, depending on the grade. I use 6mm thick tool steel, but only for the last 100mm or so due to weight, the rest is all aluminium.
    Roll bars could be a good option for self righting if your bot has the right shape for it, and added protection for the actuator is good too. Mine uses cable actuated arms to self right, but I had lots of problems with them last year due to not having enough weight for the self righting system. I worked on it over the winter and this year they have been much better in the couple of fights I have had with it so far. There is more info in the build diary if you want it.
    Downside of roll bars is that it will potentially limit the height that your crusher can have. Won't affect performance but it may stifle getting hold of taller robots.
    BW: Shu!, The Honey Badger
    For self-righting, could you create something similar to Razer? Linkage actuated wings could be made to push pretty much any way you wanted.
    Update on progress
    the CAD design is coming along nicely but still a long way off finished.
    I went for the simplist solution for the self righting by making it invertable. When it is finished it will be able to run off the top of the claw and the rear wheels and unable to stay on its side.
    triangler wedges still need to be added to the front wedge as well to catch robots and prevent the claw lifting the back end up.
    biggest problem at the moment is that its already 2.5kg over weight! Without any electrics, top lid, fasteners or the front wedges. Some work needs to go into reducing the size of the design.
