Page 15 of 20 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 194
Thread: Haynes Manual Build a Robot
  1. #141
  2. #142
    Hahhaa, that it is. I once totaled up how much my second version of The Honey Badger cost me. Close to about £400 but then again, I was things like a pricey transmitter at the time and such.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
  3. #143
  4. #144
    The thing is, as a one off, it is expensive, yes but you do end up reusing tools and components from one machine to the next as you go along. My Middleweight needs a new body but the parts from the current version can easily be transplanted so that will only cost me about £300 or 400 to get the parts and for me to machine them to make it work.
    FW: Azriel
    MW: Jibril, Kaizen
  5. #145
  6. #146
  7. #147
  8. #148
    McMullet
    Guest
    The max current from your battery is the capacity in Ah multiplied by the C rate (in this case you have a burst and continuous C rate, so use the lower of the two, i.e., the continuous rating). That's 4.0 Ah x 60 C = 240 A. The fuse must be less that that.
    However, with two drill motors and a linac you'll never get close to 240 A. So to protect your motors and ESCs you are probably better off with something around the 100 A mark, or even less. We have an 80 A fuse for a similar setup to yours.
  9. #149
    You work out the burst amperage of the battery and get a fuse below that amperage as per the rules:
    7.8.3 Fusing
    A fuse rated below the maximum burst discharge of the battery MUST be fitted. The maximum burst discharge current is calculated by multiplying the C rating by the capacity. E.g. 25C 2200mAh = 55 Amp
    So in that particular batteries case, it is 4 amps * 120C = 480amps (240amps constant). That, to me, sounds crazy and you'll likely never draw that much. I'd figure on it being a quarter of that, so 120amps but from experience, a 60 or 80amp fuse will be sufficient. I've yet to blow a 80A fuse in either my Featherweights or my Middleweights.
    FW: Azriel
    MW: Jibril, Kaizen
  10. #150
    McMullet
    Guest
    Looks like we're largely in agreement here Lucy!
