Page 12 of 18 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 176
  1. #111
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    83
    Quote Originally Posted by Shakey View Post
    If it helps I dug up the F2 data sheet (Still on the store, just tucked away): https://nutsandbots.co.uk/ftds/
    Big help thanks, i did look but couldnt find it lol
  2. #112
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    83
    Might sound like a dumb question but the red and black wire needed is that jut generic wire i can get online or in a shop?
    Or does it need to be rated to a certain level?
  3. #113
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Somewhere on the Wirral
    Posts
    977
    You can use "generic" wire, I've use white speaker wire in the past but having red and black wire (or whichever colour you associate positive and negative with) does make things a hell of a lot easier to track. It also helps with getting polarity right where getting it incorrect, such as plugging into a ESC, could cause shorting and damage to electronics.
    As for the rating for a wire, for a Featherweight, either 10-14AWG I find works well, I use 10AWG in Azriel but that is probably overkill for that robot at the moment.
  4. #114
    Roboteernat's Avatar
    Roboteer
    Status
    Offline
    Name
    Nat
    Robots
    Location
    Eastleigh, Hampshire
    Posts
    302
    I use 12AWG for my feather, its rated well for use on mine, plus its the rated wire on the TZ85A esc's.
  5. #115
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    83
    Where is best to buy some from? I used to go Maplin for anything like that but well.....lol
  6. #116
    Redirect Left's Avatar
    Roboteer
    Status
    Offline
    Name
    Adam
    Robots
    Hyperion (BW) Modus Operandi (BW) Dead Meme (FW - WIP)
    Location
    Wakefield, West Yorkshire
    Posts
    180
    Quote Originally Posted by AdamST180 View Post
    You can buy cabling quite cheap off eBay, unfortunately places like Screwfix & B&Q mostly only carry home wiring solutions, which is needlessly heavy and expensive for this. Just type, for example "12AWG Wire" (replace 12 with what you need if needs be) into eBay, you'll find some suitable results for sure. I personally have bought this listing from this seller with good results: https://www.ebay.co.uk/itm/Flexible-...2Uc9mr_KzOv5NQ
  7. #117
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    83
    Quote Originally Posted by Redirect Left View Post
    You can buy cabling quite cheap off eBay, unfortunately places like Screwfix & B&Q mostly only carry home wiring solutions, which is needlessly heavy and expenmsive for this. Just type, for example "12AWG Wire" (replace 12 with what you need if needs be) into eBay, you'll find some suitable results for sure. I personally have bought this listing from this seller with good results: https://www.ebay.co.uk/itm/Flexible-...2Uc9mr_KzOv5NQ
    Yeah i though the stuff from B&Q looked overkill, will order from that link, looks good, cheers
  8. #118
    TechAUmNu's Avatar
    Roboteer
    Status
    Offline
    Name
    Euan Mutch
    Robots
    Robots: Triforce(HW), Elevate(FW), Sideswipe(FW) ESCS: A200S
    Location
    Edinburgh, UK
    Posts
    341
    Just make sure to get silicone wire, the normal stuff tends to melt and short.
  9. #119
    Try Technobots or Component Shop.
  10. #120
    Roboteer
    Status
    Offline
    Name
    Nat
    Robots
    Location
    Posts
    302
    Agreed, Make sure its silicon and highly flexible. I bought some silicone wire from eBay and it turned out to be 16 stranded steel wire in a silicon coating. Wasn't too impressed. Should have stuck with a turnigy branded silicone wire, at least i would have got the right stuff.
    That above eBay link is a good one as they list the strand count, being 680 for 12AWG. so thats the good stuff
