If it helps I dug up the F2 data sheet (Still on the store, just tucked away): https://nutsandbots.co.uk/ftds/
Might sound like a dumb question but the red and black wire needed is that jut generic wire i can get online or in a shop?
Or does it need to be rated to a certain level?
You can use "generic" wire, I've use white speaker wire in the past but having red and black wire (or whichever colour you associate positive and negative with) does make things a hell of a lot easier to track. It also helps with getting polarity right where getting it incorrect, such as plugging into a ESC, could cause shorting and damage to electronics.
As for the rating for a wire, for a Featherweight, either 10-14AWG I find works well, I use 10AWG in Azriel but that is probably overkill for that robot at the moment.
BW: Shu!, The Honey Badger
FW: Azriel
MW: Jibril, Kaizen
I use 12AWG for my feather, its rated well for use on mine, plus its the rated wire on the TZ85A esc's.
Where is best to buy some from? I used to go Maplin for anything like that but well.....lol
You can buy cabling quite cheap off eBay, unfortunately places like Screwfix & B&Q mostly only carry home wiring solutions, which is needlessly heavy and expensive for this. Just type, for example "12AWG Wire" (replace 12 with what you need if needs be) into eBay, you'll find some suitable results for sure. I personally have bought this listing from this seller with good results: https://www.ebay.co.uk/itm/Flexible-...2Uc9mr_KzOv5NQ
Just make sure to get silicone wire, the normal stuff tends to melt and short.
Try Technobots or Component Shop.
