Results 1 to 5 of 5
Thread: Gabriel Wheel Material
    They were HDPE wheels I believe.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
    Redirect Left
    Guest
    The entire thing was constructed out of HDPE - i don't know how thick.
    As demonstrated with Gabriel - it tends to wack out of shape or bits fly off, rather than total devastation, so you can usually take a few hits before things get seriously bad for you - as demonstrated with its survival against Carbide.
    edit: Robot Wars Wikia says its 25mm thick
    Redirect Left
    Guest
    There was also a little bit of metal (steel from the look of it) for armor in certain areas.
