I did something similar with The Honey Badger 2.2 where there was a sheet of Aluminium over a layer of HDPE. Had I bolted it down properly, it would probably still be with me but it seemed to hold up quite nicely against non-spinners.
BW: Shu!, The Honey Badger
Having a bit of bother with the servo controlled linear - I took this from the Barróg thread
[QUOTE=RogueTwoRobots;468452]On point number 2, the easiest way would just be to use a servo to turn on a couple of microswitches, one for each direction. It allows you to control forward and back from one radio channel and the stock actuator motor will have a low enough current draw to not require any additional relays etc. Here's a setup in its simplest form; I usually tend to just hot glue the switches onto the sides of the servo and wrap a cable tie around them, but you may prefer a more robust/maintainable/aesthetically pleasing alternative
Attachment 6852[/QUOTE
I assume I wired it wrong. But not sure how I identify the right terminals.
My expectation was without either microswitch engaged it would be off. With one or the other polarity would be reversed.
I possibly toasted them in the process of getting it wrong.
The switch is a Z-15GW-B
The pin nearest the rocker is 1 - COM
Centre is 3 - NO
Nearest switch extended arm 2 - NC
Advice appreciated as my electrical know how is poor at best.
I think if you connect on each switch:
pin 1 (COM) to the motor
pin 3 (NO) to batt+
pin2 (NC) to batt-
I don't think you will have blown them upas long as you keep the motor connected across the 2 common pins, you should be ok.
Let me know if this works, or if you want me to draw a circuit diagram.
Paul
you're a genius! that works thanks very much
Thanks to the help of Paul I got the linear control working. At least this mock up, which powered a small 12V motor. The idea is to make a sandwich with some polycarbonate as the bread and the microswitches as the filling. Conveniently the mini servo I am using is just the right height to align with the arms.
I need some long 4mm bolts and some longer 1.5mm bolts, and in the final version the polycarbonate will shield the arms too. (Pictures updated with bolts fitted)
Last edited by Deathly Hallows; 16th June 2018 at 17:02. Reason: Pictures not shown
Got a few deliveries this week.
Bolts, nuts, titanium plate, polycarbonate
I am going to make the top mostly from polycarbonate as it's light, also it's cheap to replace so no big deal if destroyed after each event. I'll add reinforcement behind.
Did a little more work on the electrical system. Configured the buck voltage reducer to put 18V to the lineac.
Added a 'live' light, a 100A fuse for lipo and a kill switch/jumper
I am making a polycarbonate lid for the bucky and adding a fan to be sure it can handle max load.
Here's a video of my lineac controller working
Its looking really goodI am excited to see it all together.
Thanks very much.
I added some titanium plate to the front instead of that bit cardboard. It weights in at 13.02kg so once the ramp is fitted it's going to be a bit over but lots of opportunities to lower weight.
Having some electrical issues. Got it all wired up, motors spinning, lineac running, but something is not right.
