For sale,
One Motenergy ME0708 motor more commonly known as an etek. This particular specimen was used in crossfire in King of Bots. Same motor used through the competition. 3 arena appearances and some testing. Probably had less than 15 minutes run time total.
Good points,
- Cool black colouring
- water jet cut collar that has been bonded to the motor casing around the threaded holes for mounting. Essentially to stop the same issue we had with PP3D where the casing sheared around these points
- Runs fine in either direction. No crunchy bearings or untoward noises from bench testing
- The threaded holes on the front have been re-tapped to M10 and M8 depending on their size (shaft thread is still stock as we didn't use it).
Bad points,
- You can see it took a knock in the arena. The plastic brush holder at the rear does have a crack in it but is still perfectly functional and held together by the rest of the motor. You can pick up a replacement from the USA if you so desire. The dents to the side casing don't stop the rotation of the motor and as far as I can see, the magnets look to be fine.
Pics here https://imgur.com/a/dCJFx
Further info here http://www.robotmarketplace.com/products/0-emc-r.html
Price, make me an offer. You can see what they retail for new in the link above (plus import tax and shipping).
